- 5 Sep 2011
- Surrey
I had the issue with the fan rubbing on Vapor-x cards. They're just not designed with crossfire in mind. Thermally and physically
water cooling is the way to go here I think.
How about you just water cool the lower one? Depends on your budget. Judging by your hardware you aren't short on fundsSo you could go full hog and cool them all.
Or save the cash on water cooling and swap out for dual cards???
Happy to go full hog, as feel this system will last me a good while, plus would it be cheaper watercooling the 3 cards then swapping out for dual cards?
thats my asus deluxe up and running with no issues at all its a graet looking motherboard and bleeding heavy
Just had to rma my motherboard as it keeps saying no connection found on my monitor ,I tried 3 graphics cards and even stride it on 2 different monitor and tv no luck even tried different cables to the monitor and tv but no good I also checked for any bent cpu pins none found thanks god ....just hope they send a replacement as soon as can as they will receive it tomorrow..
