Fancy some coop nexus?
I'll be up for some coop tonight Tony, after 8pm though..
Steam id is tkm52..
Same here dude, first time ive manged to play longer 10-15 mins 1 hour 45 mins a new record lolRight, well that seems to have cured the crashing to desktop. Folks, if you are still having the CTD issues, try rolling your Nvidia drivers back to 335.23 WHQL:-
http://www.nvidia.com/download/driverResults.aspx/73780/en-us
Worked for me, I've just sat and played for over an hour with no crashes whatsoever.![]()
Tick the boxesNice program that!
Do I need to change any specific settings in it?
also for Dark Souls 2 ensure you put Steam into offline mode to avoid VAC ban it warns you in the Widescreen launcher for that & COD Ghosts & or any other VAC protected games you can only play with Steam offline as they flag them as bannable due to being memory hacks to give the correct FOV + Aspect Ratio which is stupid of Valve
340.52 WHQL Nvidia drivers work fine for hours of gameplay the missing game files is the biggest issue to not working properly + minimum 6GB System Ram + 3 GB VRam. Even today people are still reporting missing files on Steam
Capcom admitted that the retail version & other digital store steam keys were not getting all the files.
This launch is a mess I am surprised its still no 1 on Steam thats almost a week now![]()
Tick the boxesalso for Dark Souls 2 ensure you put Steam into offline mode to avoid VAC ban it warns you in the Widescreen launcher for that & COD Ghosts & or any other VAC protected games you can only play with Steam offline as they flag them as bannable due to being memory hacks to give the correct FOV + Aspect Ratio which is stupid of Valve
I know there's files missing there on the Steam forums to grab, either way since doing the roll back not had a single CTD like before so some thing is working
My main problem is a ctd when quitting.
Is it worth unlocking the framerate then?...A video I saw said it could cause problems or is that bs?
Assuming you’ve done all of this correctly, when you next load up the game you’ll notice that it’s no longer capped to 30 FPS. But there are a few issues you’ll have to content with. The main issue regards frame pacing and sometimes we’ve noticed animations can look a little odd. Fortunately physics operate normally. There are a few half solutions – but none that are completely obvious. Forcing VSync in the game is one way to at least minimize the frame rate fluctuations.
If you’re using an Nvidia card, you can also enable “Half Refresh”. To do this, right click on your desktop, click on Nvidia control panel and then navigate to “Manage 3D settings”. From there you’ll need to scroll to the bottom and you’ll spot an option labeled ‘Vertical Sync’. Select “Adaptive (half refresh rate)” and then click okay. You could also use the “program settings” tab to force this option only on Dead Rising 3. Personally, this is the option I’d go with – unless you want it affecting all your other games, or you’re willing to constantly swap it back and forth.
Erm.
As if Zombies were the weird part hah!
