***The Vapers Lounge***
Status
Not open for further replies.
I have no idea what any of you lot are talking about: MVP2, KFL+, 4nine, Mephisto, Akuma, fogger and on and on and that's just from the one post I can see above this quick post thing.
I need to quit though and I've asked for advice on here before and ended up buying a basic e-cig that is terrible.
All these starter kits and everything, I have no idea. There are so many pieces, building a PC from scratch whilst going cold turkey sounds less stressful.
I smoke between 8 and 15 a day of Marlboro lights, can someone just recommend be something simple, please.
What is your budget?
To be honest i woundn't bother buying something cheap, they're just not worth the effort tbh.
I would recommend this tank http://www.cloud9vaping.co.uk/epage...tPath=/Shops/yxve46fvrnud/Products/KN-AERO-V2
And this mod http://www.cloud9vaping.co.uk/epage...Products/ASP-BATT-VV/SubProducts/ASP-BATT-VV-
You get get a cheaper mod, but i would definitley get the Aerotank :)
I started off with this http://www.cloud9vaping.co.uk/epage...th=/Shops/yxve46fvrnud/Categories/Kanger_EVOD
Not had a stinky for 4 months now, all you need with the above is some juice I would suggest you get 12mg nicotine strength to start off with.
Cheers all
Looking to get some red astaire concentrate, it seems pretty standard at 9.99 per 30ml, does anyone happen to know a vendor that has a current discount code?
I've done quite a lot of checks on google/POTV discount codes but unfortunately nothing.
Chefs Vapour has a 10% discount code, "UKV".
T-Juice has a 15% discount code: Givemejuice
Never heard of Red Astaire, but just ordered some.
Received my Digby's Gunpowder yesterday but struggling to get on with it. Can anyone recommend a good fruity e-liquid which is a 'substantial' vape (if that makes any sense)? I've tried a couple of fruity ones in my usual 8mg and some are very light.
Bloody lovely.
Tried Hooligan from Digbys last night, not sure I like it..... Reminded me of Germolene! :/
The King isn't bad, but I've gone off banana flavours a bit...
Just got some hooligan, DMC, and oriental plunder.
Hooligan reminded me of germaline too.
I got some king and moriyers mix last time, god the moriyers doesn't half blow your throat off. Theres menthol then theres moriyers mix.
Om Nom Nom,
Om Nom Nom,
a bit "meh"
In that order.
The Ruthless Juices are ace, Drakes Vapes - drakeula is on the right.
I wasn't sure about Hooligan at first, but after about half an hour I was pretty sold, now I love it. Went through 30ml really quick and ordered 30ml more yesterday.
It's a strange flavour but quite complex and quite strong. It's different and I like it. Trying some Gunpowder as well this time.
I can thoroughly recommend an MVP2 and a Nautilus Mini.
I own an aerotank mini and full size, they're ok but they're not a patch on the Nautilus.
http://myepack.co.uk/aspire-nautilus-mini.html
http://myepack.co.uk/itaste-mvp-v2-0-black.html
it worked, have ordered 30ml of red astaire and 30ml of colonel custard.
That'll be the next batch of juices accounted for, if mixed at the recommended 15%, that's 400ml of juice for about 25 beans total, woop!
Completely agree with this - I use the same.
I've had several different ecigs over the last 3 years and nothing I've tried comes even close to the Nautilus Mini. The taste is great and it doesn't leak (a mouthful of ejuice isn't nice)
The MVP is great also and lasts me a couple of days before it needs charging. You can also vape it whilst it's charging if your sitting at a desk.
I would also say get yourself a pack of atomisers (the BVC 1.8 ohm version) which will give you 7 to be going on with. Each one should last about 2 weeks.
As far as liquid goes it's entirely up to you. I found a tobacco flavour was easier to kick smoking with and still prefer a tobacco flavour if I'm having a beer. You could always buy 2 different flavours to try and put one in the tank that comes with the MVP (although it's not a good tank compared to the Nautilus).
Status
