I have no idea what any of you lot are talking about: MVP2, KFL+, 4nine, Mephisto, Akuma, fogger and on and on and that's just from the one post I can see above this quick post thing.
I need to quit though and I've asked for advice on here before and ended up buying a basic e-cig that is terrible.
All these starter kits and everything, I have no idea. There are so many pieces, building a PC from scratch whilst going cold turkey sounds less stressful.
I smoke between 8 and 15 a day of Marlboro lights, can someone just recommend be something simple, please.
What is your budget?
To be honest i woundn't bother buying something cheap, they're just not worth the effort tbh.
I would recommend this tank http://www.cloud9vaping.co.uk/epage...tPath=/Shops/yxve46fvrnud/Products/KN-AERO-V2
And this mod http://www.cloud9vaping.co.uk/epage...Products/ASP-BATT-VV/SubProducts/ASP-BATT-VV-
You get get a cheaper mod, but i would definitley get the Aerotank
