T6 Ubers are now 100% drop rate.
Does this also apply to the keys or organ only ??
It's usually arcane dust that I'm lacking.
Now they just need to announce "you can now toggle what items auto pick up" allowing you to automatically loot gems, rare items, blue items, potions etc
That would be a massive QoL change imo.
Its the Uber versions of Act bosses
magda, SK, diablo, rakanoth, gohm, the bald dude in act2
Not to be cheeky... but is there any chance that somebody would be able to give me a small helping hand with some greater-rifting? I'm stuck at about rift level 23 and I'd ideally like to get a couple of gems to Level 25 for the bonuses!
Not even sure what T6 Ubers are.
So if you basically kill them on T6 there Ubers or is something else involved? .
Just the organ, keys are still RNG![]()
Ramaldni's Gifts
Your wiz has always been good Stormee. I message you a couple times to group up but never got replies, we need to do some runs on stuff together and gear share.....
I don't think/know if the effect from the strongarm bracers is effecting the black holes my duplicates drop though. I don't think it is.
https://eu.battle.net/d3/en/profile/xdcx-2305/hero/43624608
currently using balefire caster one hander for high DPS / atk sp - just found a buriza which should give me higher crit. Should I waste one of my rama gift to see if its an upgrade? Still looking for a good bow - Etrayu or good raven's wing
So, I finished the game at lvl 49, started again on hard then thought "screw it" and purchased the add on and played through that on hard.
I'm not level 62, finished the game and I take it the next step is purely doing bounties to get rift gems, then doing the rifts? Building up gear.
