Hi guys, I have been experiencing vibration while braking for a little while, and it has now got to the point where I need to get it sorted as soon as possible.
It was like it before my MOT two months ago, which I passed with flying colours, but one of the advisories was relating to "play" in the steering rack.
I don't believe that it is to do with the steering rack however, I think that it is probably due to warped disks?
It happens under braking only as far as I can tell, I haven't noticed it with gradual non-braked deceleration, nor have I noticed any vibration at motorway speed.
If I were to decelerate fairly firmly from 80MPH to zero (in say, 200 to 250 yards) the shaking is really quite bad to the point where you can hear things/trim in the cabin rattling and you can see the steering wheel shaking.
My disks were fitted new by the garage just before I bought the car a year and a half ago, and since it is a low value car, I suspect they just put £15-a-side eBay specials on.
Other points to note, the tyres are new, it was the same before getting the new tyres fitted, the wheels have been re-balanced, but I still need to have the tracking & alignment re-done.
The car is a 2002 VW Polo 9N 1.2 AWY, and yes the notorious bushes have been replaced, as have several other components to the front of the car which are known for wear and tear.
