** CRAZY 780Ti DEAL: PERFECT FOR SLI UPGRADES!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well Gigabyte have just given me a truly insane deal on 780Ti and 780Ti GHz!
Stock arrives next week, so this is perfect time to SLI Upgrade!!!! :)
Gigabyte GeForce GTX 780Ti GHz Edition 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TGHZ-3GD) @ £369.95 inc VAT
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
8-Phase power Design, compare to reference 6-phase power design, GV-N770OC-4GD V2.0 makes the MOSFET working at a lower temperature and provides more stable voltage output. Besides, over temperature protection and load balance to each MOSFET can effectively extend the card life.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1085MHz
- Core Boost Clock: 1150MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£569.99] Inc. VAT
Only £369.95 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) @ £349.99 inc VAT
GIGABYTE, the world leader in high-performance gaming hardware and system, is pleased to announce the latest graphics card, GeForce GTX 780 Ti Overclock Edition (GV-N78TOC-3GD). With 25% plus CUDA cores than GTX 780, the most powerful thermal design in the world and exciting new technologies, GV-N78TOC-3GD is going to bring all the gamers an extremely gaming experience to a whole new level. The exclusive WINDFORCE 3X cooling design guarantees you to dissipate 450 watt heat out. Enjoy your game play with a stunningly beautiful and quiet design is no longer a dream. It also supports OC GURU II and GPU Boost 2.0 for maximum clock speeds. GV-N78TOC-3GD features PhysX® and TXAA™ technologies for smooth, sharp graphics, and GeForce ShadowPlay™ to capture all your greatest gaming moments automatically. Whether you play on 4K monitors at extreme settings, GV-N78TOC-3GD can provide the horsepower to drive all your next-gen gaming visual experiences.
GIGABYTE innovatively presents WINDFORCE 3X 2-SLOT cooling system, thinner and cooler! The thermal structure contains three ultra quiet PWM fans, an only 2-slot height heat sink with exclusive "Triangle Cool" Technology, two 8mm and four 6mm cooper heat pipes and a high-performance RAM heatsink.
The innovative thermal design guarantees the heat dissipation capability to over 450watt. The cooling performance is 14% significantly better than stock fan! WINDFORCE 3X 450W cooling system not only provides an effective heat dissipation capacity, but also gained a higher performance with lower GPU temperature through the GPU Boost 2.0 technology.
According to the latest NVIDIA® technology, GPU BOOST 2.0, GV-N78TOC-3GD provides gamers an unlimited overclocking capability. By using GIGABYTE exclusive OC GURU II, gamers can monitor and adjust all important settings such as GPU clock, memory clock, fan speed, voltage, power target, OSD and online support. With the upgrade and easy-to-control user interface, GIGABYTE OC GURU II becomes the best mate while using GV-N78TOC-3GD.
Specification:
- GeForce GTX 780Ti
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Features:
- MAX your overclocks with NVIDIA's Power Balancing
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)
- GPU Boost 2.0 Technology
Was [£499.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Hm, ordered an EVGA SC 980 elsewhere....now thinking of cancelling and getting the GHZ edition of this. NOt sure if the 980 is worth the £60 extra...
