As you seem to be more clued up then me (admittedly I'm noobtastic when it comes to monitors and setting them up) care to share what settings you use for me to try? I have backed off monitor brightness to 40 and moved some other settings about, not as much glare from the screen but colors do seem deeper.
Ok bud, will do. Spent about 2 days calibrating and testing this monitor. I should point out I've not used a monitor calibration tool (yet, I don't have one but may pick one up). I've been using my Dell IPS as a side by side comparison which came with a certified sRGB calibrated setting from the factory (even got a piece of paper!) with a very low Delta-e value for colour accuracy (low is good).
I've mainly been working on the colour settings, and some slight gamma tweaks on the Swift to get it as close to my dell as possible in a range of uses. Just using my eyes and brain, which are very good
So, for you and anyone else that may be interested, these are my settings:
Monitor itself
Brightness: 21
Contrast: 50
Colour temp: User (R: 96 G: 96 B:100). Don't use any of the colour temp presets, they are all ass.
ICC/ ICM profile
In windows colour management (find it in control panel) I'm currently using the "ICM" profile that comes with the monitor driver, that you have to download and install from the Asus support website (for some stupid reason it's not on the CD that comes with the monitor).
It's called "Asus PG278Q color profile, D6500"
I've also tried the ICC from TFT central, but for now I'm finding the one described above to be a bit better.
Look on TFT central for info and guides about colour profiles and how to use and install them properly. IT'S IMPORTANT http://www.tftcentral.co.uk/articles/icc_profiles.htm
Gamma tweak
The following is a work in progress. From the reviews I've read the gamma settings are supposed to be spot on straight out of the box (a 2.2 reading is supposed to be ideal), but I think it's just slightly too bright, on mine anyway. There is no actual monitor setting to tweak gamma on the Swift, so you have to do it in the NV control panel. I keep slightly changing and altering the values, but this is what I'm doing currently:
- Open NV control panel, go to "adjust desktop colour settings"
- Go to "2" and click the use Nvidia" settings radio button
- Slide the gamma slider down to between 90 and 95 depending on your taste. I'm on 92 at the moment
- Stay away from digital vibrance or hue! It's really not necessary and will really **** things up, especially hue. If you must add a bit of vibrance, be very careful and don't go over 55. (It's like photo editing, less is more really).
And that's it for now. With these settings I find it very very good for a TN panel in terms of colour accuracy. It also performs and looks well in various tests you can see at Lagom, especially the blacks http://www.lagom.nl/lcd-test/black.php - worth a look at the other tests too.
I'm still tweaking slightly so it's a work in progress, but I hope this helps.
(I'll write up my findings on gaming later hopefully. Gsync is mostly good, but I'm a bit disappointed in some games tbh. Also - THERE IS AN ISSUE WITH BF4, SLI and Gsync as has been reported on blurbusters! Get terrible slight judders, worse than using regular vsync. At present I have to completely disable SLI in the NV control panel (Not just run on single card in the game profile) and run on one card only. This then is nice and smooth with Gsync, but it's disappointing not to be able to run higher framerates. Must be a driver issue, so let's hope it gets sorted.)
