I need to make a side for the bath, i was thinking of using ply wood and them sticking some tiles on to it, i was wondering tho, how would i attach it to the wooden frame i will make around the bath? i want to have access to the underneath of the bath but didnt really want to drill through the tiles and screw it on. Would velco work? does anyone have any tricks for this kind of thing? im not sure velco would be strong enough.
hard to explain but I'd do this:
attach a second thin frame to the back of the sheet with tiles on. Into this add some screws, 2 on each side. Then use your drill to cut out holes through the main wood frame. It's just a case of lift, push and drop to put it into place.
Was hard work and my first major task. Also managed to realise why the AC door was dropping, builders hadn't put the screws in the hinges -_-
