I don't get why everyone is arguing this still.
What if gaming wasn't your primary reason for wanting a 4k monitor?
Is upscaling from 1080p to 4K really that terrible?
That was my point really, it seems pointless to have 120 or 144hz monitors if you're not striving to consistently hit that
If you're blind
I don't get why everyone is arguing this still. At this moment in time with current GPU hardware, you cannot max out modern games and have a consistent high frame rate experience at 4k.
Mate, I had both side by side on my desk... The benefits of 144hz and gsync outweighed the benefit of 4K by a large margin
Now, if you use your monitor from 6 inches away then yeah, otherwise it'll be 39" screens before I go back to 4K
I previously ditched 1080p/120 to go 1440/60, but with 1440/144 vs 4K, the 1440 has won
I can see what you are saying, but I get the point Vega is trying to make too, for the majority of people given achoice between ROG and 4K, it is probably preferable to go Rog, but as with most things the only way to tell is to try both side by side
I also said limited, not "no benefit"
It's subjective. There are objective differences, but the importance between the differences is subjective.
Yes you can, I do in every game, and so do most 4k owners.
Completely agree. You need to sit very close to 4k 28" monitors, perhaps 1ft away to see the benefit. With 1080p to 1440p it's very easy to spot even 2ft back at 27".
Another benefit i found with the ROG is being able to play games on max settings still if there are no SLI profiles like dead rising 3. I get in the late 30's to mid 40's in heavy areas at 1440p and with g-sync it's really playable. At 4k in the same area's i was getting in the 20's, totally unplayable even if you had g-sync. Although this game is badly ported i still want to play it and the ROG makes it possible with a single high end gpu. SLI profiles or lack of is a major consideration sometimes. If SLI was available for every game then sure with my triple SLI setup 4k 60fps would be great as it is on games that use SLI and i love it.
Overall the ROG can take advantage of SLI with super slick, low lag high fps gaming and when forced to use 1 gpu you still get really good fps aided by g-sync. 4k relies on SLI a hell of a lot so unless nvidia get there arses into gear the ROG makes more overall sense for now at least to me.
60fps, constant, MAX settings at 4k, in ALL games? Not possible, sorry.
No not 60fps constant, more like 90, my setup kills 4k, no need to apologise, we don't expect you to know everything![]()
Aww bless still have to result in using swear words do we? You probably haven't tired 4K as your 780ti setup wouldn't have the memory to run most games over 60FPS but it doesn't mean other people cant. I'm running 5930K and CF290X's.
For any-one that's interested, using BF4 as an example with my setup I used to average 120FPS with lows of 90FPS on 1080p, with 4k its down to 90FPS average and lows of 60FPS.
I could never go backwards now from 4k, I bought one half expecting to send it back but when I fired up the desktop and BF4 everything was so crystal clear I couldn't believe my eyes, BF4 looked more like BF5, I felt like I was in a Optimax advert and everything went HD. Downscaling to 1440 or using 1080 at work now feels like I'm viewing the monitor under water, you don't realise how blurry it is till you've had it 4k sharp.
Yes, I already said that and then gave my opinion on those differences. You countered by stating that to have come to that opinion I must be "blind". Last time I checked there were objective tests for blindness that dont involve the persons preference of 1440/144 vs. 4K.![]()
I am more interested in larger displays though, I'd prefer a 39-40" UHD display over anything else, except maybe a 30" 5120x2880 display ran at 2.0 scaling.
If you can run a ROG at 120-144fps then you have the 'juice' to run 4k at 60fps+ with game settings at max. If GPU's cant run 4k at 60fps then they cant run 1440 at 144fps either but G-sync will help with those lower framerates no doubt. ROG is a clever future profer, G-sync for todays mid range cards and 144hz for when you upgrade to run 144hz
Philips have an upcoming 40" VA-based UHD display. I was quite impressed with what I saw of it at IFA.![]()
