- 6 Nov 2002
- London UK
Painting...lots and lots of painting.
Kimi, Theres nothing wrong with tiling onto ply for a bath side panel, thats exactly what I did and its still good 4 or 5 years on. Think you might have to put a coat of primer on it first, to stop the ply sucking all the moisture out of the tile adhesive too fast.
As for how to hold it in place, some ball catches would work. You would just have to use a suction cup on the tiles to pull it out.
http://www.macbuildingproducts.com/images/09CATCHDOUBBR.gif
Wiring up bath and shower pumps, running earthing straps to all the new plumbing, all jobs which i enjoy doing![]()
Rewired my shower but still trips the MCB on the full power (2 elements), still works on Eco ( 1 element)
So i guess the element has died.![]()
What rating is the mcb and what kw rating is the shower? It may be tripping on overload rather than a knackered shower.
80Amp MCB and 9.5kw shower on a 2yr old 17th edition Consumer unit and 10mm2 wiring.
It trips out instantly.
If your consumer unit is 17th edition and you have your main bonds in place then supplementary bonding isn't necessary mate.
