- 27 Oct 2013
- Sheffield
Just to add to this - got my K70 RGB (red switches) yesterday and after reading about this issue noticed that the \ key isn't lit up. That does seem to be the only key that isn't liit though, the others that people have mentioned are fine.
P/N: CH-9000068-UK
As an aside, when I unpacked the keyboard, the mute button had fallen off and was loose in the cellophane packaging the keyboard was wrapped in. It seems to be OK (and is lit) after fitting it and doesn't come loose when shaking the keyboardMaybe something for others to watch out for as well.
My \ key does not work either. However if i unplug the usb cable and reconnect it turns on before the software kicks in and overrides the default red/white setting the light does turn on. See if it does the same for you.
