I'm not certain but I think I read AMD cards can't do 144hz through display port.
....I've left mine on Normal, but there is Extreme and Off to choose from too.
The TFT central review recommends to leave at normal, using the blurbusters tests.
So what have fellow Swift owners got the Overdrive setting at? Any point messing around with it? (Never had a fast monitor before with this setting)
I think Normal is perfectly fine just as TNT Central said, and the only setting that I ever will use![]()
Feel cheated I paid 670 for this on Saturday and now its gone down to 637.![]()
It now gone down to £629.99....Well they refunded me the difference, fantastic service from ocuk![]()
Anyone wall mounted the swift? I take it any Vesa 100 mount will fit ok?
Providing your wall mount is a normal 100x100 then it'll fit snug like mine does. The vesa mount isn't flush with the back it sits inside the back of the monitor slightly....if that makes sense?![]()
Is this supposed to be like this ?
If you look at the monitor bezel, there looks to be about a 2-3 mm black border around the screen before you see the viewing area ?
Yes. It's a panel border, very common on monitors with very slim bezels.
