Long purple line on my monitor ? :(
19 Feb 2007
Northampton
I turned my monitor on a few minutes ago and it flashed and then when I got on to the desktop a purple/black line appeared from the top to the bottom on the right hand side of the screen roughly 1-2 pixels wide.
I've tried the screen on 3 different PC's with DP and HDMI and it's still there, Borked screen or is there some type of fix and explanation for this ?
Example below -
If you've tried it on three different PC's and the line is in exactly the same place on all three then yes, I'm afraid it's borked. Got Warranty?
Yep 2 year manufacturers, I'll see if I can take it back to the place I bought it seeing as it's only 2 days old, Local retailer.
If you've only had it 2 days then I would be expecting the retailer to offer a straight swap or refund. They may try and palm you off to the manufacturer but your contract of sale is with them, not the manufacturer.
No.
It is the monitor. I have one in the cupboard which has had a purple line like that, in almost the same place, for years.
Take it back. :)
Its like a stuck pixel, but a whole column of them.
No.
Take it back. :)
Thanks for the reply, You sure a BSOD couldn't cause this just say from a bad GPU overclock on a 980 and a sudden short going through the display port cable or is that not possible ?
There is zero chance that a BSOD would do that. If it was a broken GPU, possible but it would be more extreme, plus the fact you have tried it on 3 different PC's proves it is a faulty panel.
Thanks for the reply, I also unplugged the DP cable and it went to the "No Signal" screen and I could still see extremely clearly the thick black line going down the screen.
My Dell 2408WFP has a line like that, only it's about 4 or 5 pixels wide now. They change colour as the monitor warms up and they eventually fade out of view. If I switch inputs I can still see them.
I'm just hanging onto this screen for a while longer until I decide what to do about a replacement.
