R9 290X Owners Thread
Try this fix:
http://www.tomshardware.co.uk/answers/id-1656824/atikmdag-sys-error-bsod-startup.html
Step 1: Download and install the latest ati graphic driver.AND DONT TURN OFF OR RESTART YOUR COMPUTER AFTER INSTALLATION
Step 2: Then go to C:\Windows\System32\Drivers and rename atikmdag.sys to atikmdag.sys.old.
Step 3: Go to ati directory (usually in C:\ATI) and find the file atikmdag.sy_.
Step 4: Copy the file to your Desktop directory.
Step 5: Open cmd.exe by going to Start -> type cmd in the search box and hit enter.
Step 6: Change the directory to Desktop by typing chdir Desktop.
Step 7: Then, type EXPAND.EXE atikmdag.sy_ atikmdag.sys. Or,
expand -r atikmdag.sy_ atikmdag.sys
Step 8: When the expansion is complete, copy the new atikmdag.sys from your Desktop to
Step 9: Restart your computer and the problem should be resolved.
Without that fix, I get constant blue screens, could be once a day or up to 5 times a day, doesn't matter if the PC is idle, browsing, gaming or just watching a film.
Tried stock CPU clocks, upping the power control, afterburner settings/clocks, reinstall of bios etc. no change. Only the above has semi fixed it for me, still get a blue screen every now and then but nowhere as much.
I have the reference cooled one.
I have no OC right now.
I'm almost certain the code was 0xa00000001, but the last crash the BSOD was all skewed and I couldn't read it.
System is old, I'm in the process of upgrading, but it's gradual.
CPU: i7 920.
Memory: 6GB CORSAIR XMS3 1333MHz (3x2GB)
Motherboard: ASUS P6T DELUXE
Psu: Brand unknown atm 700W
SSD: samsung 840 EVo
I am currently at work, so all dumps etc will need to wait till later.
That sounds exactly the same as mine! Same error code and I also have had a few blue/BSOD screens skewed looking.
Try the fix I posted above, it should fix it/reduce the BSOD's....
CPU: i7 920.
I'm familiar with your issue. I had the same when i had a P8P67 WS board. The problem is the gpu is not compatible with the NF200 pci-e switching chip on your motherboard. Sometimes at idle i found i would get that bsod. The issue was resolved by using a different board that did not use the NF200 chip. I'm afraid there is unlikely to be an update from the motherboard manufacturer now.
I would recommend trying Nexsus18 suggestion.
I'm going to have to ask to be removed from the owners club :(
I've sent my card back because the draw of the 980s was just too strong.
I couldn't help it they were shiny and new...
(Plus if I ever get around to watercooling 3 identical cards will be easier than a 295x2 and 290X)
Can i have another entry in the OP please Kaap. :)
Matt ma boy, you just made me spill man juice.
Honestly I would love to have 2 lightnings but I think the cooler would cover my over slot for the sound card and I just can't go back to onboard sound.
