*** The 2014 Gym Rats Thread ***
Its no big numbers but whatever, I'm finally telling 70kg on bench press, which for me considering I could barely press the bar without shoulder pain just over a year ago I'm exastatic about :) now I just need to sort my squats out! Hopefully on the way to improving my push press and potentially have a 190kg deadlift come year end.
That's brilliant work mate, just shows what putting some effort into fixing yourself can do rather than just ploughing on.
I've been very lucky with my shoulder issues they seem to have naturally sorted themselves out as I've gotten stronger.
Have some Coach Wu push press tipz:
http://instagram.com/p/t8oZOdofpy/?modal=true
Coach Wu (@wuchuanfu) asks the question, “Which movement looks faster?”
Here’s a breakdown on the video and question posted last week:
Movement A looks faster, but if you observe, the period that the bar is being driven up by the the legs is short, with the arms and shoulders kicking in early. This cuts the amount of leg power being transferred to the bar. Whereas in Movement B, the leg drive is long, allowing maximum power transfer to the bar. The bar is unweighed from the leg drive and the arms/shoulders just follow through to the receiving position.
In Movement A, there is much more arm drive than necessary. This creates excessive tension in the arms/shoulders. You can see this from the receiving position, where it looks like the body is in a state of max tension. Having excessive tension when receiving the bar can cause unwanted force transfer to the joints and lower back. Because of the arms punching up early, this creates a brief disconnect between the body and the bar, with the load suddenly jarring back into body in the receiving position, creating similar issues related to max tension.
Movement B is performed in a controlled and relaxed state. The body is constantly connected to the load, allowing for a smooth transition into the receiving position. Being strong yet relaxed is ideal because this allows you to have awareness of the bar’s placement and allows for any minute adjustments.
In summary, Movement B is preferred because:.
i. We have constant awareness of the load and body positions, allowing us to identify where the bar is throughout the movement. This allows us to perform the movement consistently at different loads.
ii. Leg drive is maximised and tension in shoulders/arms and lower back is reduced. More leg drive=bigger loads being moved.
iii. With good control and awareness, we minimize the incidences for strains on the wrist, elbow, shoulder and the lower back.
iv. Higher power delivered to the bar=Higher movement speed.
I cut 2 stone leading up to July. From 11st where I was genuinely fat as **** to 9st, at 5ft5 and looked reasonably shredded with a fair amount of size. I've been bulking since September and currently 9st 8 and Abs are starting to dissappear is 8lbs in 6 weeks too much and when should I stop really? I Don't want to get fat and have to cut for another 6 months to get where I want to be id rather keep it controlled and make cutting easier but at the same time want to gain more muscle.
Suggestions?? I've never been on a bulk before, either gone all out getting fat not caring or I've been cutting and counting my macros.
http://www.bodyrecomposition.com/muscle-gain/general-philosophies-of-muscle-mass-gain.html/
http://www.bodyrecomposition.com/muscle-gain/macronutrient-intake-for-mass-gains-qa.html/
http://www.bodyrecomposition.com/muscle-gain-mistakes/
I'm a sucker for dat Chinese weightlifting secret haxxors. Here's some other videos from that seminar:
The front squat and rack position - note this is different to how it's usually taught and I still can't get it right myself - using the lats to support the bar and getting the hand into the bar more:
Back squat - the idea of maintaining balance from start to finish (keeping the centre of mavity over the middle of the foot), tempo, and the idea of not over-tensing the upper body (hence the 'don't need to use your hands' thing) so they you can feel/focus on the legs taking the load:
For the weightlifters...
The 'power' position:
First Pull:
The 'Panda Pull' aka snatch grip high pull with knee rebend (the closest movement to snatching that isn't a full snatch):
Clean high pull:
The jerk:
I love how short both his legs and arms are. :D
The way he effortlessly catches all those push presses onto his traps makes me jelly. If I did that I'd end up in a wheelchair! All about the timing and being springy when the bar drops I guess.
No excuses in weightlifting but damn squatting looks a hell of a lot easier at that height.
For leggy squatters, see Tom Martin lol. Also yeah, no excuses... (<63kg lifter):
Yeah, I am a big fan of the Lifthard guys and their work because of the "debunking" of Western weightlifting theories.
The ever-so-subtle differences in training/technique highlighted by both tthese and the Klokov seminars are fascinating and show how far the US and UK have to go in terms of take-up and progession to serious "elite" performance...
The moar u no:
Coach Wu was in the same 'class' as Lu Xiaojun and Liao Hui - I can't remember if he either got injured or just moved away from competing - but ended up as a coach (currently of the Singapore weightlifting team, I think). Obviously this gives him a great deal of first-hand experience of 'The Chinese Method'.
Kirksman who runs LiftHard trained under a few different coaches before him (I think a Bulgarian and then a Russian) and worked with Wu for a few years before he went to SG. The exposure he gave to Wu led to Western coaches being aware of him and as ever, CrossFit got word and Diane Fu of Fu Barbell organised seminars around the world.
There are a few American coaches like Nick Horton who are applying some of the training principles, I think, but as ever, with such a small pool of lifters they've got a massive disadvantage. I've noticed CrossFit is leading a lot of people into weightlifting though, which is nice - Camille LeBlanc Bazinet looks like she could make the Canadian national team and you have 'defectors' like Jess Kinzler at MDUSA.
Sadly, I very much doubt we will ever see a Crossfit-bred weightlifter win at elite level (national competitions in this country and the US do not count), in the same way Klokov and Slivenko will never win at Crossfit.
Until our countries pay our athletes or support them more effectively, they will - quite simply - never be as good as the Asians or Soviets. :(
Indeed. I'd like to see Camille do well, but IIRC her current total, which I believe was better than any of the American women in her weight class this year, would have placed her 4th... in the 48kg category - and she's a 58kg lifter. Long way for them to go.
They missed one of her CnJ's - she was 6 for 6.
They're not supports, they're sleeves - they mainly keep the knees warm and don't add any numbers to your squat unless you buy ridiculously tight ones which act in a similar fashion to knee wraps.
Interesting how Kirkman talks about not pushing knees out and not trying to lift by loading the hips and posterior chain - kinda the opposite of what is currently repeated as conventional wisdom.
I see lots of guys in the gym using the Rippetoe 'butt up' technique to get them out the hole when squatting and you can see the centre of mavity going back and then forward, so the bar does not travel in a straight line upwards.
The explosion of Crossfit has brought it on, and it is generally great advice for a lot of people.
However, watch Kirksman, Xiaojun Lu and a lot of other national Chinese lifter squat and it is VERY diffwrent to Klokov, Lovchev, Ilyin and - my current loltastic lifter - Mart Seim...
Why?
Because their anatomies are different. Whilst there are certain key points in squatting, everybody is different and mives differently, and therefore needs coaching accordingly. Bringing the knees in ON THE CONCENTRIC part of the squat (never eccentric) requires quads of doom, but misses out the posterior chain... whether this is better or worse depends on a gazillion different factors, but if your torso isn't quite upright in the first place it can cause collapse in the lumbar spine, meaning back ache and discomfort in the long term.
Try it on a warmup some time and you will feel the difference very clearly.
