Just got my first Exotic Bounty which appears to be the one for Thorn. Done the strike (lvl 12 cheese
) and the Hive kills but now have the 500 PVP kills and lvl 26 "special" strike to content with. *YAY*
The PVP bit sounds a pain but is relatively straight forward. I have a legendary void auto shotgun so that should do the trick on the smaller maps. The strike though sounds a pain in the backside.
As long as I keep my Super charged I should be ok on the dying from as my Sunsinger Warlock can just self revive. Is there a limit on the number of times you can use this, or is it just a case of as long as you have a charged super you are ok?
I suppose at the end of it, is Thorn even worth it?! It looks awesome but what is it like to use?!
