Sick score of 8pack.
but why are 4 980 getting lower gfx score then 4 290x
(8 pack(no1) vs Wizerty(no3))
my guess would been more for 4x 980
64005 on GFX is superb. Not sure where 4 290Xs have scored higher?
All the instructions for submitting a score can be found at MLG (click my sig link)
.Here.
But ofcourse it doesnt beat the 980s in total score because for whatever reason even with lower GS and lower or equal physics Nv setups score higher on Combined even though its just graphics tests ontop of physics.
Here.
Rangerjr1 you appear to be a time traveller2095! Fantastic GS score
As said 4 way SLi scaling is poor at the moment
lol 5.262, how much vcore Ranger?![]()
Like 1.55v for 5.262GHz, why? lol
Edit: You refering to that xfire run? The CPU must've been unstable there because the physics seems a bit low actually for the clocks.
Edit 2: http://www.3dmark.com/fs/3046543
Here's a score i did last night experimenting with my CPU, does a lot better on the physics![]()
I know Rangerjr1 will have a pop over the CPU, however personal best so far with a single R9 290(P) X.
i7 [email protected] Ghz Water Cooled
290(P) Flashed to X @1,220 Mhz/1,536 Mhz Watercooled.
AMD 14.9 drivers
SCORE
11517 with AMD Radeon R9 290X(1x) and Intel Core i7-3770K Processor
Graphics Score 13988
Physics Score 10982
Combined Score 5116
http://www.3dmark.com/3dm/4504496?
, try it out! And yes you really really should OC that i7 more if you want higher scores, whats keeping you from doing it
