Sid Meier's Civilization: Beyond Earth Benchmark
Man of Honour
21 May 2012
Dalek flagship
Settings.
DX11
Mantle
To run the benchmark you need to.
Explore to your steam library and right click the Beyond Earth .exe file.
* Click "Properties".
* Click "Set Launch Options".
* Type into the field "-benchmark lategameview" (without the quotations so it reads -benchmark lategameview).
* Click OK and launch the game.
Next time you run the game it will go straight into the benchmark.
Don't forget to apply the correct game settings before starting the benchmark.:)
Simple Rules.
Any normal resolution can be used up to and including 4K.
Please post your GPU and CPU clocks.
Please post your result in the format as shown below in the spoiler.
Please post what drivers you are using.
Please state if you are using DX11 or Mantle.
290X @1000/1250
1080p
DX11
290X @1000/1250
4930k @4.0
14.9.2 Driver
Converting Results
Please use the utility below.
Credit due to:
Havana_UK for working out how to convert the data.
GoogalyMoogaly for creating the utility.
Gregster for hosting the utility.
Many thanks.:)
Convert Results Here.
To use
Find your result file "lategameview".
This will be in the "\ProgramFiles(x86)\Steam\SteamApps\common\Sid Meier's Civilization BeyondEarth\" folder.
Use WordPad to open the file.
Copy and paste the contents into the utility above.
Press Calculate FPS.
Thread Navigation Links.
1 GPU 1080p
  1. Average 144.45, Minimum 75.22, GPU 980 @1482/2102, CPU 5960X @4.0, Kaapstad Link DX11 347.09 Drivers
  2. Average 140.05, Minimum 81.45, GPU 290X @1270/1625, CPU 5960X @4.7, AMDMatt Link Mantle 14.12 Drivers
  3. Average 130.93, Minimum 48.09, GPU 980 @1503/2013, CPU 4930k @4.5, Spudley Link DX11 344.48 Drivers
  4. Average 129.32, Minimum 32.77, GPU nvTitan @1226/1879, CPU 3930k @4.625, Gregster Link DX11 344.48 Drivers
  5. Average 124.09, Minimum 40.89, GPU 290X @1150/1500, CPU 4690k @4.6, savagesam117 Link Mantle 14.12 Drivers
  6. Average 119.03, Minimum 51.31, GPU 780 @1189/1700, CPU 3570k @4.2, Ian Evey Link DX11 347.09 Drivers
  7. Average 112.74, Minimum 47.03, GPU 970 @1500/2003, CPU 4770k @4.2, GamingSlug Link DX11 344.48 Drivers
  8. Average 111.96, Minimum 33.07, GPU 780ti @1294/2000, CPU 4770k @4.5, Havana_UK Link DX11 344.48 Drivers
  9. Average 110.29, Minimum 32.07, GPU 290P @1150/1450, CPU FX-8350 @4.5, humbug Link Mantle 14.12 Drivers
  10. Average 100.45, Minimum 31.10, GPU 280X @1080/1550, CPU 4790k @4.6, thebennyboy Link DX11 W10ES Drivers
  11. Average 83.63, Minimum 42.42, GPU 290X @1000/1250, CPU 4930k @4.0, Kaapstad Link DX11 14.9.2 Drivers
  12. Average 71.95, Minimum 22.99, GPU 290P @977/1250, CPU 2600k @3.5, shankly1985 Link DX11 14.9.2 Drivers
  13. Average 68.95, Minimum 42.00, GPU 7970 @1125/1575, CPU 3770k @4.4, Dygaza Link Mantle 14.9.2 Drivers
  14. Average 68.24, Minimum 25.32, GPU 290P @1040/1350, CPU FX-8350 @4.5, humbug Link DX11 14.9.2 Drivers
  15. Average 60.76, Minimum 30.85, GPU 7950 @1250/1600, CPU 2700k @4.5, eddyr Link DX11 14.9.2 Drivers
  16. Average 59.39, Minimum 28.67, GPU 7970 @1125/1575, CPU 3770k @4.4, Dygaza Link DX11 14.9.2 Drivers
  17. Average 48.03, Minimum 17.24, GPU 280X @1110/1575, CPU FX-8320 @4.7, thebennyboy Link DX11 14.9.2 Drivers
  18. Average 34.85, Minimum 13.43, GPU 570 @883/1086, CPU X6 1090T @3.8, siriq111 Link DX11 344.48 Drivers
2 GPU 1080p
  1. Average 80.57, Minimum 11.94, GPU 280X @1100/1550, CPU FX-8320 @4.8, thebennyboy Link Mantle 14.12 Drivers
  2. Average 72.21, Minimum 20.49, GPU 280X @1100/1550, CPU FX-8320 @4.8, thebennyboy Link DX11 14.12 Drivers
3 GPU 1080p
4 GPU 1080p
  1. Average 228.18, Minimum 23.94, GPU 980 @1502/1962, CPU 5960X @4.5, Kaapstad Link DX11 344.75 Drivers
1 GPU 1200p
  1. Average 123.49, Minimum 47.78, GPU 980 @1503/2013, CPU 4930k @4.5, Spudley Link DX11 344.48 Drivers
  2. Average 83.25, Minimum 32.45, GPU 780 @1100/1550, CPU 3570k @4.2, Ian Evey Link DX11 344.48 Drivers
2 GPU 1200p
3 GPU 1200p
4 GPU 1200p
1 GPU 1440p
  1. Average 49.12, Minimum 13.27, GPU 290X @1000/1250, CPU 4790k @4.4, pete910 Link opengl 15.5 Drivers
2 GPU 1440p
3 GPU 1440p
4 GPU 1440p
  1. Average 228.11, Minimum 18.64, GPU 980 @1492/2002, CPU 5960X @4.5, Kaapstad Link DX11 347.09 Drivers
1 GPU 1600p
2 GPU 1600p
3 GPU 1600p
4 GPU 1600p
  1. Average 223.82, Minimum 18.73, GPU 980 @1492/2002, CPU 5960X @4.5, Kaapstad Link DX11 347.09 Drivers
1 GPU 2160p
  1. Average 68.24, Minimum 40.76, GPU 290X @1265/1625, CPU 5960X @4.7, AMDMatt Link Mantle 14.12 Drivers
  2. Average 62.70, Minimum 14.35, GPU 980 @1502/2102, CPU 5960X @4.0, Kaapstad Link DX11 347.09 Drivers
  3. Average 48.82, Minimum 34.82, GPU 290X @1290/1625, CPU 4930k @4.8, Kaapstad Link DX11 14.9.2 Drivers
  4. Average 48.81, Minimum 35.20, GPU 290X @1275/1625, CPU 3970X @4.9, AMDMatt Link DX11 14.9.2 Drivers
2 GPU 2160p
  1. Average 80.51, Minimum 17.34, GPU 290X @1230/1625, CPU 4930k @4.0, Kaapstad Link DX11 14.9.2 Drivers
3 GPU 2160p
  1. Average 106.53, Minimum 15.56, GPU 290X @1230/1625, CPU 4930k @4.8, Kaapstad Link DX11 14.9.2 Drivers
4 GPU 2160p
  1. Average 154.31, Minimum 18.76, GPU 980 @1492/2002, CPU 5960X @4.5, Kaapstad Link DX11 347.09 Drivers
  2. Average 112.10, Minimum 15.44, GPU 290X @1220/1625, CPU 4930k @4.8, Kaapstad Link DX11 14.9.2 Drivers
Currently the best driver to use for Civilization Beyond Earth with Mantle is 14.9.1, until 14.9.2 driver hits.
Not a game I will be playing. But I have read the long and bigger the game becomes the more CPU demanding it gets. I remember this when I was younger and used to play RollerCoster Tycoon the bigger your park the more demanding it became to run.
So my point is, is this benchmark tool a true representation of the performance one can expect.
Will get my first results in shortly after 6pm UK time when it launches in Aus :)
Edit: Unpacking now. Should have downloaded to SSD because this is taking ages!!!
That was going to be my first question too when I saw them discussing this on the AT forums.
On the one hand you'd think the developers would know this and base their benchmark on this, but on the other hand it is possible that using the built-in benchmark will be about as useful as testing a new graphic card with aggressive temperature based boost using a built-in 30 seconds benchmark in a on open air rig. That is, not very useful at all. For graphic card reviews I have almost given up on any of the English language review sites because of this.
Whelp, won't be playing this one yet!
It doesn't allow any resolution greater than 1280x1024 in fullscreen. Possibly because 144hz rog swift.
Can play windowed...
I switched to my other monitor, and the game runs full screen (2560x1600@60hz).
However, I can't find the benchmark in the menus.
Think the game needs patching!!!
Thanks Matt!
Everything maxxed including 8x MSAA I got ~155fps, but the benchmark doesn't give you a post-bench summary, so you just have to watch it and grab a middling number....
A friend of mine just streamed me the bench over skype, WOW, So boring, Seriously, It's more boring than wet paint but at least with wet paint you can see progress ! :p
Thanks Matt!
Look in the C:/steamapps/common/CIV folder. :)
I have placed the settings in the OP and ran the bench myself but I can not find where the results are being stored.
