At least I'm not the only one then, looks like they have some major network problems to me lets hope they sort it asap because game servers have gone form 20ms ping to 110ms!
Had 152mb fibre installed earlier today but my speedtest shows the following:
This is over wireless, but its connected at 400mbps as the router is in the next room. Theres also no other wireless networks in range of all 3 of my wireless devices that are broadcasting SSIDs anyway. Any ideas?
Also check if you have put 60Mb into your QOS settings.
VM just lie
Switched to VM in Dec 2013 after leaving in March 2011 because the never sorted of a utilisation fault.
now I've had a utilisation fault since March 2014, they've told me loads of times they are upgrading the node I'm connected to (Lichfield) and by 24/9/14 it will all be sorted and I'll get the 150MB boost as well.
Today I was getting 0.1 MB, after a router reboot, 3.3MB.
After a phone call I was told March 2015 it will all be sorted.
So 12 months of crap BB out of an 18 month contract, maybe 15 months based on them never fixing the issues.
As soon as I can I'm off and I'll never have VM ever again.
You should be able to claim back your money... I mean it should be legal. Maybe consult Citizen's Advice?
You can only claim back so much on you broadband bill.
So far I'm basically getting £25 off my bill every month. But I basically have to phone up every month to get it.
Since I left Sky less than 12 months ago I can't return as a new customer yet, so it's basically suffer VM until, December and switch back to Sky.
If VM try and enforce the remainder of my 18 month contract then I'll consider contacting Trading Standards.
I'd rather have the constant, rock solid 35MB with no disconnects and zero loss of speed, I used to get from Sky, than what I get from VM
