Another £550 build
26 Jul 2012
Hi there, I'm looking to make another £550 build. Just wondering if there are any better parts I can get than my last build a few months ago. I'll need everything except for the OS, keyboard, mouse, speakers and monitor. I'm essentially just looking to get the best build possible for the budget.
Lastly the current monitor is a old VGA one which will be upgraded soon, so I'll need a HDMI to VGA converter as well.
Thanks
It maybe missing parts such as DVI-DSUB adapter (shouldnt need that in 2014 anyway) and a maybe a driver disk, (download the latest from AMD).
As long as the actual card is fine thats all that matters, It is Gigabyte so at least the warranty+customer support is the best.
I've just changed a few items (such as the SSD I had put in) and I've got about another £30 to play with for the graphics card. Would a GTX 760 be better on worse than the previously mentioned card? Thanks again.
I guess I'll go with the B Grade card then. As mentioned before the current monitor is an old VGA one so I assume I'll need a HDMI to VGA converter.
It may come with the card, who knows till you open it up.
P.S DVI-I to VGA adapter is what you want.
