Any other ocuk guilds about on other servers than silvermoon?
Turn off vsync, and in the options.ini limit your fps to your monitor refresh rate, disable triple buffering and then enable reduce input lag.
Since patch 6 the game forces your fps to drop by half, so if your monitor is 60hz, and your pc can only output 58, it forces it down to 30 to stay in sync, so if you are at less than 30 it forces it down to 15, and so on.
The settings I posted above stopped it for me. ("reduce input lag" doesn't slow the game down as you would think either)
There is now no requirement to collect items you just run the risk of getting trash instead of a usable item, Not sure if this is pandaria only or if it is game wide.
Wait there is an alliance OCUK guild on silvermoon? I have all 6 of my 90s there and never knew this!
Who to /w for an invite?
Does anyone know if theres any point doing the Iron Horde quests before the expansion? Wont we be losing out on XP?
I could be wrong but I would expect them to be removed with the expansion as they are pre-expansion event stuff, like the portal stuff before TBC or the plague stuff before WotLK, or the Deathwing stuff.
If XP is that important to you then do a full set of daily quests ready for hand in and hand them in on patch day, you should grab 1/4-1/3 of a bar but I always found it spoils the levelling experience.
I wouldnt of thought so at this stage, how are your professions?
I'll be using my free boost so they'll be maxed out.
I'll just finish levelling my 88 warrior I guess.
