- 25 Nov 2011
- The KOP
Edit double post.
AMD confirmed during its second quarter earnings call back in July of this year. That the company has plans to ship a myriad of 20nm products in 2015. Including 20nm professional graphics and client products. AMD’s now CEO, then COO, Lisa Su stated the following :
“20nm is an important node for us. We will be shipping products in 20nm next year and as we move forward […],” said Lisa Su, senior vice president and chief operating officer of AMD. “If you look at our business, it is quite a bit more balanced between the semi-custom, embedded, […] professional graphics […] as well as the more traditional sort of client and graphics pieces of our business. [20nm] technology plays in all of those businesses.”
We’ve reported yesterday that AMD’s next generation Fiji XT GPU may very well be ramping. This GPU which is supposedly going to power AMD Radeon R9 390X GPUs, has appeared in Zuaba’s import database . Shipping from AMD’s graphics business offices in Canada to Hyderabad India. The shipped item was the PCB assembly for the GPU, likely for testing and validation purposes.
Am sure mantle 2.0 already has this covered. But it is a good question about past games. How does the 285 run mantle theses days?
Developers have zero incentive to release a patch so unless AMD cough up which is about as likely as me winning the lottery nothing will happen.
Hmmmmm, so the die and memory will be on a single package? I suggest that it will generate a fair bit of heat in that case, maybe that 390X will have a hydro option after all...
(or they'll be radically improving the oem cooler!!)
two 390s 1440p 144hz display all before May?Hmmmmm, so the die and memory will be on a single package? I suggest that it will generate a fair bit of heat in that case, maybe that 390X will have a hydro option after all...
No, other than the IMC (Integrated Memory controller) its not any different to any other GPU, it still has external PCB Memory IC's.
If legit, it must be 20nm as the extra 40% of Stream Processors on the die would make this 615mm^2 in size, compare that with Hawaii at 438mm^2 and GK110 at 550mm^2.
Not a chance, way to big, its 20nm which means a reduction in power consumption.
