- 31 Oct 2006
Start of my new hifi rack. Will be another shelf where the nuts can be seen above the ryobi case. Inspired by another members homemade rack I saw here.
Replaced the guttering at the rear of my house. It was raining and probably not the best time to do it.
I've still got the side to do.
That's something I plan to do at a later date, did you use a scaffold tower or just work from ladders ?
A ladder stand-off is great for doing gutters. If its PVC guttering you can do it from a ladder on your own, but cast iron or wood you'll need two people, or a tower if doing it yourself.
Don't tell me your switch cable goes up the wall and across above the door where its been plastered :O
I need todo this too.. the front is easy but the back has a conservatory so I'll need to enlist nextdoor to have a walk way over the conservatory.. also need the conservatory gutters doing too.. but that's over a pond..
Anyone used one of those hedgehog things to prevent build up and make it easier to clear?
Oh and moved the light switch to the correct side of the door and plastered over the old back boiler.
Boarded the loft in my new place. Just moved in properly, so had to get that done so I could put my empty boxes and stuff up there. The middle was already done. There was one strip light, but got a second put in so its nice and bright.
All you need to do now is put some battens across the V in truss's and put line of floor boards across for shelving
When I moved I had two lofts full of junk - I don't think I took anything that was in the lofts
Dave
