Nope
its just like everything Else in Destiny - completely random.
Only problem is that Destinys random number generator doesn't appear to be that random, which is why you get the same control map 4 times in a row, and get no loot 4 drops in a row on the raid.
Just need to do VoG but i have no friends .....![]()
Not sure on the MIDA - finding it not as good as the VoC but unsure if its more the wierd needs the patch added for exotic weapons.yea the Mida is a great weapon just got the first 5/6 upgrades in about 10mins handing in 20 bounties from 2 guardians on it.
Really wanted Ice Breaker before the DLC came out but we will have to see
So I noticed two nights ago one of my pads R2 button skips working half way through firing an auto rifling. I switched to Pad 2 last night and found it was even worse with my Vision of Confluence!
Is this the sign of the end for both my pads? - REALLY surprised both would go at the same time as one of them hardly gets used.
Bloody sods law lol
Purchased the Multi Tool of Xur yesterday thinking yea this is a solid weapon that i could get along with and then BAM did the Raid last night with some guys of reddit and i end up with the VoC and the Praedyths Revenge sniper rifle in one go lol ok so which one do i use my Energy on ???
If you have an icebreaker then don't bother levelling the Praedyths revenge unless you have excess materials. If you don't have the icebreaker, then upgrade it up to the bonus oracle damage and it will have its uses but Vision of Confluence should be your priority.
Personally I would just sack the mida off and focus on the Vision of Confluence. You can always level the mida later on but I find it to be a weak exotic weapon and it would be more beneficial for you to use exotics in your special/heavy slot instead.
Iron Banner grinding is soul destroying.
Anybody need the nightfall on ps4? Just solo'd it to prime but don't think I'll be able to beat it on my own my 26![]()
