£££ ALL BLACK FRIDAY GRAPHICS CARD DEALS NOW LIVE!! £££
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
That's it guys, all my Black Friday deals on graphics cards are now live and available for ordering. All prices go up 10am Tuesday next week or when stock sells out, whichever comes first:
Gigabyte AMD Radeon 295 X2 Dual GPU 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 3yr
Was [£699.95] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 970 "Mini-ITX" 4096MB GDDR5 PCI-Express Graphics Card (GV-N970IXOC-4GD) @ £259.99 inc VAT
Measuring merely 17cm in length, the card, specially built for small form factor PCs based on mini-ITX motherboards. Packed with GIGABYTE’s unique blade fan design, pure copper heat pipes and patented ‘Triangle Cool’ technology, delivering superior cooling capacity at an extremely low noise level given its compact size.
The air flow is split through the triangle design at the fan edge, and is guided smoothly through the fan by the special 3D stripe curve design, effectively enhancing the air flow by 23% over traditional fans, whilst reducing air turbulence.
“Triangle Cool” fan-sink integrates a patented triangle-shaped aluminum block into the aluminum extrusion module. The triangle design not only minimizes the turbulence between extruded aluminum fins, but also enhances heat dissipation to improve cooling efficiency for the whole fan-sink.
Features:-
- Powered by NVIDIA GeForce GTX 970, the latest MAXWELL architecture
- Suitable for small form factor PCs and mini-ITX motherboards
- Flex Display technology(patent-pending)
- 17cm length design with unique blade fan and patented “Triangle Cool” Technology
- 26.8 dB in 3D gaming (14Db lower than reference in 3D gaming)
- GIGABYTE Dual Bios technology
- Ultra Durable graphics card components.
- OC GURU II with GPU Boost 2.0 Technology
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1076MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
Was [£269.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90101-10P) @ £239.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
Was [£251.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £284.99 inc VAT
Features:-
- WINDFORCE 3X cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 970 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1178 MHz / BOOST: 1329 MHz
- System power supply requirement: 550W (with one 6-pin and one 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
- Flex Connectivity (Upto 6 Monitors)
Specification:-
- GeForce GTX 970
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Was [£299.99] Inc. VAT
Only £284.99 inc VAT.
ORDER NOW
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £265.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1140MHz
- Core Boost Clock: 1279MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Was [£275.99] Inc. VAT
Only £265.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 970 AMP Extreme Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90103-10P) @ £295.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1203MHz
- Core Boost Clock: 1355MHz
- Memory Clock: 7200MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 176W TDP
Was [£329.99] Inc. VAT
Only £295.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 970 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C97U-1SDN-M5DNX) **OcUK Exclusive** @ £287.99 inc VAT
The GeForce® GTX™ 970 is a high-performance graphics card designed for serious gaming. Powered by new NVIDIA® Maxwell™ architecture, it features advanced technologies and class-leading graphics for incredible gaming experiences.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1305MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1 x DVI, 3 x DP and 1 x HDM
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £287.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) @ £263.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1114MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Was [£281.99] Inc. VAT
Only £263.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 980 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C98U-1SDN-M5DNX) **OcUK Exclusive** @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1266MHz
- Core Boost Clock: 1367MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Review: http://www.kitguru.net/components/g...980-ichill-herculez-x4-air-boss-ultra-review/
- Warranty: 3yr
Was [£499.99] Inc. VAT
Only £449.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 980 AMP Extreme Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90203-10P) @ £499.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1291MHz
- Core Boost Clock: 1393MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 209W TDP
Was [£529.99] Inc. VAT
ORDER NOW
Palit GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card @ £949.99 inc VAT
If you crave only the very best, then Titan Z is exactly that, featuring a pair of the most powerful gaming GPU's available, Titan Black Editions fused onto a single PCB. Featuring a whopping 5760 CUDA Cores and a massive 12GB of GDDR5 memory operating on a 786-Bit interface, makes this the perfect card for a 4k monitor setup.
With advanced dynamic power balancing and 12 phase power supply, not only is this card incredibly fast out the box it also sports some very impressive overclocking ability as well. Power balancing ensures both cores are locked at the same speeds always to ensure the smoothest possible FPS experience with no micro-stutter of any kind.
NVIDIA keep noise levels to a minimum by using an extra-large axial fan to keep this beast of a card as cool as possible along with dual vapor chambers and a 60% larger fin stack area.
Tested at 3840x2160, with AA and high settings on a 3960X at 3.3GHz yielded above 40fps in Batman, Crysis 3, Bioshock Infinite, Battlefield 4, Far Cry3, Metro Last Light and Tomb Raider, making this truly a 4k capable gaming graphics card.
Also being a Titan GPU it is ideal for BIOinformatics, Computational Chemistry, Computational Fluid Dynamics, Computational Structual Mechanics, Data Science, Defense, Electronic Design Automation, Computational Finance, Imaging & Computer Precision, Medical Imaging, Weather & Climate and Numerical Analytics.
Features:-
- 450W Cooling ability at 2700rpm
- 375W Power requirement (Stock Clocks)
- Maintain over 40fps in the latest games at 4k resolution
Specification:-
- Cuda Cores: 5760
- Base Clock: 705MHz
- Boost Clock: 876MHz
- Single Precision: 8.1 Teraflops
- Double Precision: 2.3 Teraflops
- Memory Config: 12GB / 768-Bit GDDR5
- Memory Speed: 7000MHz
- Power Connectors: 2x 8-Pin
- TDP: 375W
- Outputs: 2x DL-DVI, 1x HDMI, 1x DisplayPort 1.2
- Interface: PCI-Express 3.0
- Warranty: 2yr
Was [£1039.99] Inc. VAT
Only £949.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 8192MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
<h1>Specification</h1>
<b>Radeon R9 290X</b> <br />
- Backplate included: Yes <br />
- GPU: Hawaii XT <br />
- Litecoin Hash Rate: 850-1000 <br />
- Stream Processors: 2816 <br />
- ROPS: 64 <br />
- Core Speed: 1040MHz <br />
- Memory Speed: 5000Mhz <br />
- Memory interface: 512-Bit <br />
- Memory capacity: 8192MB GDDR5 <br />
- Cooling: MSI Twin FrozR Gaming Cooling <br />
- PCI-Express X16 lane required <br />
- 600W or greater PSU required <br />
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Warranty: 3yr
Was [£379.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
<b>Radeon R9 290</b> <br />
- Coil Whine Reduction Technology (Exclusive to Powercolor)<br />
- GPU: Hawaii Pro <br />
- Litecoin Hash Rate: 800-950 <br />
- Stream Processors: 2560 <br />
- Memory Speed: 5400Mhz <br />
- Memory capacity: 4096MB GDDR5 <br />
- Cooling: 2-Slot Blower Fan <br />
- 750W or greater PSU required <br />
- Warranty: 2yr
Was [£221.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290 Tri-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-00-40G) @ £217.99 inc VAT
- Core Speed: 1000MHz <br />
- Memory Speed: 5200Mhz <br />
- Warranty: 2yr
Was [£225.99] Inc. VAT
Only £217.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) @ £233.99 inc VAT
Sapphires 290 Vapor-X is the fastest 290 on the market with a core clock of 1050MHz but even more impressive is the 5600MHz memory clock and with 4GB of RAM making this card perfect for 4K resolution and latest games such as Titanfall, Diablo 3 etc.
The Vapor-X cooler is simply the best cooler available full stop on any 290 card, it operates in near silence but has incredibly powerful cooling ability making this a great card for both gamers and overclockers.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Core Speed: 1030MHz
- Memory Speed: 5600Mhz
- Power Connectors: 2x 8-pin required
- Warranty: 2yr
- Kitguru Review: http://www.kitguru.net/components/g...280x-vapor-x-oc-and-r9-290-vapor-x-oc-review/
Was [£249.95] Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card @ £139.99 inc VAT
With 3GB of the latest GDDR5 memory and 1792 stream processors, and support for DirectX 11.2, the architecture is built to play the very latest games with perfectly smooth action even at higher resolutions such as 2560 x 1440. In fact its Ultra HD graphics processor can feed even the latest 4K displays with the HDMI 1.4a interface. The R9 280 family represents a breakthrough in cost:performance.
Specification:-
- Litecoin Hash Rate: 500-700
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 850MHz
- Boost Clock Speed: 940MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£169.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 225W TDP
- Warranty: 3yr
Was [£307.99] Inc. VAT
ORDER NOW
Gigabyte GeForce GTX 980 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £449.99 inc VAT
GIGABYTE WINDFORCE 3X 600W cooling system once again break the record and bring the air cooling capacity up to 600W by only using 2 slots heights. The WINDFORCE 3X 600W cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes , special fin architecture, unique blade fan design, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching. Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Features:-
- WINDFORCE 3X 600W cooling system
- Powered by NVIDIA GeForce GTX 980 GPU
- BASE: 1228 MHz / BOOST: 1329 MHz
- System power supply requirement: 600W(with two 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1228MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: L=312mm, W=129mm, H=43mm
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
- Bit-Tech Review: http://www.bit-tech.net/hardware/graphics/2014/10/02/gigabyte-geforce-gtx-980-g1-gaming-review/1
Was [£479.99] Inc. VAT
ORDER NOW
MSI Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
ORDER NOW
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
Was [£679.99] Inc. VAT
ORDER NOW
XFX AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
Only £479.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 EX OC "Black Edition" 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4TX) @ £259.99 inc VAT
Features:-
- Extreme factory overclock
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1164MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Was [£289.99] Inc. VAT
ORDER NOW
Asus GeForce GTX 780Ti ROG Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card (MATRIX-GTX780TI-P-3GD5) @ £359.99 inc VAT
The ASUS Republic of Gamers (ROG) Matrix GTX780 Ti is a new graphics card that squeeze breathtaking performance from the latest GeForce® GTX 780 Ti graphics-processing unit (GPU).
ROG Matrix GTX780 Ti has been built on the renowned and highly-trusted ROG Matrix legacy as the coolest, quietest and most-readily-overclocked graphics cards available. DirectCU II cooling and CoolTech fan technologies combine with the brand-new Memory Defroster feature to create the perfect balance between spectacular power and out-of-the-box simplicity - all dressed up in the seductive ROG wardrobe.
With support for next-generation 4K/UHD (ultra-high-definition) gaming resolutions of up to 4096 x 2160 pixels, the Matrix GTX780 Ti delivers an incredible gaming experience today and far into the future.
It benefits from hand-chosen cores to deliver clock speeds that are streets ahead. Respectively, the cards speeds along at 1050MHz and 1072MHz (boosted) - that's an incredible 50MHz and 144MHz faster than reference designs.
For serious games-players this means a significant performance boost of up to 13% for super-smooth frame rates that refuse to stutter. With up to 4GB of high-speed DDR5 video memory on board the Matrix GTX780 Ti enables gamers to enjoy very high resolutions and detail levels.
This new ROG Matrix series card is brimming with advanced and exclusive hardware and software features designed to make overclocking as simple and safe as possible.
Memory Defroster is a brand-new feature that's designed to excite extreme overclockers. This clever technology quickly defrosts the graphics card's memory during below-zero overclocking to ensure sustained stability. Extreme overclockers will also appreciate the Matrix series' liquid-nitrogen (LN2) jumper switch, as it enables even more overvolting options - allowing the most adventurous users to unleash maximum greater power from their graphics cards.
The ROG Matrix series' Safe Mode allows users to overclock with complete confidence, as a single button push will restore default BIOS settings instantly.
To support stable overclocking, this card is also equipped with exclusive DIGI+ voltage-regulator modules (VRMs) with Super Alloy Power technology. The DIGI+ VRM delivers 14-phase power and digital voltage regulation, while Super Alloy Power's Japanese-made 10k black-metallic capacitors, 14 ultra-high-amperage full-molded chokes and extremely-efficient MOSFETs all withstand much greater stress and heat due to the application of specially-formulated materials.
The combination DIGI+ VRM and super-strength Super Alloy Power components means that the Matrix GTX780 Ti is forged for high-load performance and extreme overclocking without annoying whines and buzzes noises - so hardcore overclockers can enjoy plenty of headroom for experimental performance tuning without creating gameplay distractions.
ROG Matrix GTX780 Ti stays ultra-cool at all times, thanks some highly advanced and unique technologies - DirectCU II and CoolTech fan technology.
DirectCU is an innovative thermal technology that's exclusive to ASUS. It puts highly-conductive 10mm copper cooling pipes in direct contact with a card's GPU, so heat is dissipated quickly and with extreme efficiency. As well, the new ROG Matrix series introduces a new heat-sink that's finished in a stunning matt black, so the cards look as great as they're kept cool.
This card also features CoolTech fan technology. The CoolTech fan employs a hybrid blade and bearing design, with inner radial blower and outer flower-type blades to provide multi-directional airflow that accelerates heat removal to ensure high-end graphics performance that's highly stable. The fan's ramp is carefully tuned to ensure minimal noise.
For a final dash of style that's loaded with substance, ROG Matrix even features a gorgeous color-coded LED: this shines brightly and changes shade to reflect the GPU's load level, providing a useful visual guide for both casual and hardcore gamers.
The new ROG Matrix card includes GPU Tweak, an easy-to-use utility that gives users intuitive control over GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds, so they can overclock easily and with high confidence.
The exclusive ROG edition of GPU Tweak adds detailed GPU load-line calibration and VRM-frequency tuning, allowing incredibly fine control over multiple parameters for maximum overclocking and the potential to break world records.
As well, the GPU Tweak Streaming tool lets users share on-screen action over the internet in real time - so others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1000MHz
- Core Boost Clock: 1072MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£399.95] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1080MHz
- Memory Speed: 5000Mhz (Samsung IC)
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290X 4096MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
- ROPS: 64 <br />
- Core Speed: 1030MHz <br />
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode) <br />
- Warranty: 2yr
Was [£239.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
XFX Radeon R9 290 DD 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDFD) @ £191.99 inc VAT
OcUK has negotiated special RMA terms with XFX which allows OcUK to express RMA any XFX item purchased from ourselves within 48 hours. Also exclusive to OcUK we allow the removal of the stock cooler for those wishing to water-cool their XFX product or change the cooler.
Specification:-
- GPU: Hawaii Pro
- ROPS: 64
- Core Speed: 947MHz
- Card Dimension (cm) : 29.5 x 14.3 x 4.2
- Card Dimension (inch) : 11.61 x 5.63 x 1.65
- Warranty: 2yr
Was [£215.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Asus GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £455.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £455.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 780Ti OC "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card (ZT-70505-10P) @ £281.99 inc VAT
This is a truly exceptional deal as this GTX 780Ti OC from Zotac which boost to over 1000MHz offers GTX 970 beating performance, it even beats overclocked GTX 970's (when overclocked), yet the cost is the same for a card that performs close to GTX 980 levels. This is a close out sale and is limited to the stock we have incoming which is only 1000 units, were expecting them to sell out so fast especially considering the FREE games bundle and 5yr warranty! Perfect for those who want the fastest 1080P sub £300 card on the market or are looking for an SLI upgrade.
Experience PC gaming like never before with surreal visuals and world-class performance with the ZOTAC GeForce GTX 780 Ti OC. The ZOTAC GeForce GTX 780 Ti OC ushers in the next generation of PC gaming with unmatched visual realism and performance for the most demanding gamers and enthusiasts.
NVIDIA 3D Vision Surround technology enables the ZOTAC GeForce GTX 780 Ti OC to drive up to three displays for high-quality triple display gaming with immersive stereoscopic 3D effects. NVIDIA 3-Way SLI readiness lets the most demanding enthusiast gamers combine up to three ZOTAC GeForce GTX 780 Ti OC graphics cards for up to a 280-percent performance boost.
Specification:-
- GeForce GTX 780Ti
- Core Base Clock: 941MHz
- Core Boost Clock: 1006MHz
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- FREE Splinter Cell Compilation
- Review: http://forums.overclockers.co.uk/showthread.php?t=18629948
Only £281.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 780Ti AMP "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card (ZT-70503-10P) @ £299.99 inc VAT
Put your gaming experience into overdrive with the insanely fast and powerful ZOTAC GeForce GTX 780 Ti AMP! Edition. The ZOTAC GeForce GTX 780 Ti AMP! Edition amplifies the stellar series with elevated clocks for that extra performance boost in demanding gaming situations.
NVIDIA 3D Vision Surround technology enables the ZOTAC GeForce GTX 780 Ti AMP! Edition to drive up to three displays for high-quality triple display gaming with immersive stereoscopic 3D effects. NVIDIA 3-Way SLI readiness lets the most demanding enthusiast gamers combine up to three ZOTAC GeForce GTX 780 Ti AMP! Edition graphics cards for up to a 280-percent performance boost.
Specification:-
- GeForce GTX 780Ti
- Core Base Clock: 1006MHz
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
Was [£359.99] Inc. VAT
ORDER NOW
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £349.99 inc VAT
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.<br /><br />
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.<br /><br />
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!<br /><br />
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.<br /><br />
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.<br /><br />
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.<br /><br />
Specification:-<br />
- ROPS: 64 <br />
- Memory Speed: 5500Mhz <br />
- Power Connectors: 2x 8-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort<br />
- Warranty: 2yr<br />
Only £349.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 280X Vapor-X OC 3072MB GDDR5 PCI-Express Card @ £179.99 inc VAT
High-end graphics card use more power, which means they get hotter quicker. With the innovative Vapor-X, we were the very first to apply aerospace-industry vapor chamber technology to graphics cards. It's a pioneering way to accelerate heat away from the graphics chips into the rest of the cooling system.
Sapphire Vapor-X technology is used in conjunction with a heatpipe and fan assembly. The vapor chamber accelerates the heat away from the graphics chips into the rest of the cooling system. How? Inside the vapor chamber, a liquid coolant is vaporized at the hot surface. The resulting vapor moves across the chamber where it condenses at a cooled surface. Then the liquid is returned to the hot surface to aid in superior cooling.
Features:-
- 2nd generation Vapor-X technology
- Factory overclocked
- Quiet and efficient cooling
- UEFI support
Specification:-
- Litecoin Hash Rate: 550-750
- Core Clock Speed: 950MHz
- Boost Clock Speed: 1070MHz
- Stream Processors: 32 CU / 2048 ALU
- Memory Width / Speed: 384 bit / 6200MHz
- Power: 250W TDP
- 2yr Warranty
Only £179.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 980 Superclock ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2983-KR) @ £439.99 inc VAT
The new EVGA GeForce GTX 980 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£469.99] Inc. VAT
Only £439.99 inc VAT.
ORDER NOW
Asus GeForce GT 210 SILENT Low Profile 1024MB GDDR3 PCI-Express Graphics Card @ £14.99 inc VAT
Silent passive cooling runs 0dB quiet, perfect for hushed gaming and multimedia joy. ASUS low profile HTPC and multimedia-focused graphics cards are optimized for smooth 1920x1080 streaming and Blu-ray 3D. Effectively blocks 66% radiations to protect user's health and improve graphics clarity.
Features:-
- Exclusive 0dB thermal design dissipates heat efficiently with no noise generated
- Ideal for home theater PCs and multimedia centers with its low profile, high-efficiency, low-consumption design
- Native HDMI on board for full HD 1080p entertainment
- Enhanced durability and protection with GPU Guard and EMI Shield
Specification:-
- Core Clock: 589MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1200MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 16
- Shader Clock: 1238MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 3 Years
Was [£17.99] Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
This is as a good as our pricing can get, all prices are going up on Tuesday or whenever stock sells out whichever comes sooner. DO NOT MISS OUT! All items are also in stock at present!!! :)
Apart from the 295x2 I'd agree, just look like normal sales to me.
We've pushed the 9xx series as low as we can go, it is hard to offer something stand out on latest generation product that is in shortage and with weakening exchange rates.
At least our prices are the best and we have stock. :)
You will never get for example a 970 sub £200, whilst it is current and in shortage, crazy deals only ever happen on graphics cards when they are at the end of their life cycle, hence the 295 X2 deal. :)
It looks like ill definitely be adding another reference 290x to my machine with a price like that.
Yeah the 290X is actually a real stand out price, a few have missed that, the smart ones have bagged it as it comes with 4 free games too, get a good price for all of those games and your looking at getting a 290X for £160, now that is a stand out deal and all our competitors are over £250 on that product. :)
When our pricing is already pretty much the best in the UK, its hard to push those prices even lower. :)
Though a 295 X2 at £479 is a real stand out to be honest. :)
Yeah I understand it doesn't make sense for you to sell at a loss.
Do you get no help from AMD / nVidia (or board partners) on events such as Black Friday?
At the around £260 mark what would be the best card to get from this list?
Current specs:
Asus M5A97 Evo R2.0
Amd 8320
Superflower golden green 650W
Phanteks Enthoo Luxe
Radeon 5850
So i have about 350 to spend..what would be the best one to get?? I was hoping a 980 would drop to about 380 as i would have stretched to that!
The inno3d 980 after the sale of the game will be about £380. Otherwise just save a good chunk and get a 290x, you won't notice a difference in the majority of games.
I was looking at the inno 3d for 399, just wondering if it's much difference from a 290x at the expensive end or similar as the inno3d is the cheapest 980 model or does that not really matter?
I think the price drops are decent.
Just bagged that PCS+ 290 for £199, with the games it works out peanuts for such a nice card.
Hope it arrves for tomorrow!
Gibbo, you said that there would be no MSI deals on the 970 before christmas, now I've only just purchased a 970 G1 and it's cheaper
Upset :(
You have to just love the Titan Z even when it has its price slashed and put up on a black Friday deal, it is still over twice the price of the 295X2....laughing out loud.
