Already Confirmed it won't be available at launch. Likely another few weeks after, possibly even new year ? They haven't given a date, just said it will be later
i can help this afternoon?
i need to do that stage as well, i know maybe two other people. maybe we should try and meet up and do it together?
Way around it 3v3?
Cool, give me a poke when you are online and we'll see if anyone else joins.
There is absolutely no reason for the new raid to not be launched on the 9th. Delaying access to the VoG made sense: people needed to get to 26 and it allowed Bungie to ensure server stability(!) in readiness for some of those longer checkpoints.
Delaying the roll out this time around serves only to irritate the community and I honestly can't see Bungie being so naive. I am confident we will be raiding come a week on Tuesday.
can give you a hand if you want on my 29 hunter, have heard its a *female dog* to do, golden gun should help
anybody about now that needs to do the nightfall ??? done it on my hunter and titan but my 26 warlock fancies his chances just needs a hand loaded with maxed void and burn weapons
Your help would be much appreciated. If you still need help with the Nightfall I can help with that as well. Need 200 fusion kills for pocket infinity.
PSN is AStaley.
just taking a break from destiny at the moment but will be back on later, what time do you plan on doing it ??? your best of adding me then it will pop up when my ps is back on, psn in my sig
already done NF now did it with a mate
K, solo'd the 200 kills I needed so now have Pocket Infinity. Not heard back from Willems so do you want to try two manning it? I can be on for around 8pm?
Just reading this - http://www.reddit.com/r/DestinyTheGame/comments/2nucug/crotas_end_will_be_available_day_one/
Looks like it will be available on the 9th but maybe we will have to unlock by doing some things for Eris first, which makes sense.
it cant be done with 2 needs 3, how did you solo the 200 kills ????
I've not looked for a spot on the Moon, but when I did this bounty, it was during the Archon Priest Nightfall on Venus.Ran past all the mobs to the point were you get the 3 waves, then positioned myself on the top left platform and used a void fusion to take down the trash. Used my stun grenades on the bigger mobs and then pounded them, then retreat to door and chip away. And then basically repeat. It took me quite a few runs to get the 200 kills, probably averaged around 25 kills.
I've seen Xyor solo'd, but don't fancy trying it.
That would suck. How has nobody pointed out that organising the raid with your friends or normal raid group will require the entire group to have finished the other missions first. You want to do the raid so you smash through the story in a couple pf hours and then... oh no, 2 of the group are at work today and havent done it, one is online but messing about doing the nightfall and the others havenet been able to download the dlc yet due to connection issues.
I really hope the dlc goes smoothly, but i really dont have much faith that it will.
Xyur the unwed isnt really that hard. Me and martin did it with the two of us in one afternoon for the entire bounty. 500 void kills included.
I read this on the Bungie forums as well, but I'm sceptical. It just doesn't make sense to have the hard difficulty a level above the maximum attainable level. It also goes against the levels pattern that was set by the VoG where normal was 4 levels below the maximum and hard was the same as the maximum.Normal mode is rated at level 30 and hard at level 33 - http://planetdestiny.com/crotas-end-difficulty-30-33/
