). Poor eye piece quality can ruin the experience and the supplied 10mm eye piece is pretty poor, but the 20mm isn't too bad. The 20mm is an erecting eye-piece, useful when you start out as the non-erecting show you a picture that is upside down. I'd recommend picking something like this up to replace the 10mm and would recommend one of these too. On a clear night, star clusters and the moon with its abundance of craters will fill this eye piece and convert even yourself!
The quality is immense for the price and what you see is certainly worth the price tag. If she was to upgrade in future, neither of these would be replaced.
A Barlow (like this) works well with the latter eyepiece (I own these two myself, soon the purchase the 9mm), but I find that with more magnifying eye-pieces, the telescope begins to struggle and the picture becomes too blurred. It is certainly a capable scope and perfect for beginners.![]()
Hey all,
I'm looking to pick up a telescope as a present for the better half's birthday. She's never used a telescope before but is definitely keen on astronomy + space; follows all the ISS and Nasa stuff, watches the launches, enjoys looking at the sky and trying to pick out objects by eye etc. so I'm pretty sure splashing out on something fairly decent isn't going to end up being a mistake. Let's say I'm looking around £200, £300 absolute maximum
I've been reading up on this a fair bit already but since I found this thread I thought why not get some opinions in here too. Having read around I was looking at something like the "Celestron Astromaster 130EQ" plus a 2x Barlow eyepiece to go with it...
Thanks for the responses guys, my only concern with the "Skyliner" one is that without a tri-pod doesn't that limit you to standing it on a table or something similar? Or am I not understanding something and actually you can attach it to a tri-pod?
Based on the review above it sounds like the 130EQ might be a good pick... You reckon even without the motorised tracking computer thing a beginner can pick up how to find some different objects in the sky without too much difficulty? (certainly the Moon I guess is pretty easy, but some of the other planets and things?)
... Wait, is the Skyliner a lot bigger than I think it is then?
Wow, okay I was way off, I was thinking the tube itself was more the size of the 130EQ making the whole unit quite little. I guess it's fairly weighty? At the moment we have the advantage that we've just moved to the in-development edge of a new-build estate and they haven't even installed street-lights yet so its very, very dark outside... but supposing eventually it gets too light around here to get as much out of the telescope at home, will something that big be quite awkward to transport to take it to places to get some good views?
I guess this will show up the fact that I'm also a complete novice, but the mount on the Dobsonian - the swivel of the base I guess is in the plane of the surface of the ground and then you have the up/down tilt of the scope, is that easier to track things with than an EQ mount? (which as I understand it allows the scope to rotate in a few directions which you align with the spin of the planet or similar..)
Phases of the moon in 2015 (Northern Hemisphere), without and without annotations:
Rosetta’s measurement of the deuterium-to-hydrogen ratio (D/H) measured in the water vapour around Comet 67P/Churyumov–Gerasimenko. The measurements were made using ROSINA’s DFMS double focusing mass spectrometer between 8 August and 5 September 2014.
Deuterium is an isotope of hydrogen with an added neutron. The ratio of deuterium to hydrogen in water is a key diagnostic to determining where in the Solar System an object originated and in what proportion asteroids and/or comets contributed to Earth’s oceans.
The graph displays the different values of D/H in water observed in various bodies in the Solar System. The data points are grouped by colour as planets and moons (blue), chondritic meteorites from the Asteroid Belt (grey), comets originating from the Oort cloud (purple) and Jupiter family comets (pink). Rosetta’s Jupiter-family comet is highlighted in yellow. Diamonds represent data obtained in situ; circles represent data obtained by astronomical methods. The lower part of the graph shows the value of D/H measured in molecular hydrogen in the atmosphere of the giant planets of the Solar System (Jupiter, Saturn, Uranus, Neptune) and an estimate of the typical value in molecular hydrogen for the protosolar nebula, from which all objects in our Solar System formed.
The ratio for Earth’s oceans is 1.56 ×10–4 (shown as the blue horizontal line in the upper part of the graph). The value for Comet 67P/Churyumov–Gerasimenko is found to be 5.3 x 10–4, more than three times greater than for Earth’s oceans. The discovery fuels the debate on the origin of Earth’s oceans and whether asteroids or comets played the bigger role in delivering water.
A colour image of Comet 67P/Churyumov-Gerasimenko composed of three images taken by Rosetta's scientific imaging system OSIRIS in the red, green and blue filters. The images were taken on 6 August 2014 from a distance of 120 kilometres from the comet.
More information via the blog: Comet 67P/C-G in living colour
Credits: ESA/Rosetta/MPS for OSIRIS Team MPS/UPD/LAM/IAA/SSO/INTA/UPM/DASP/IDA
