- 4 Oct 2005
- Herefordshire
I'm ditching my DDC's to D5's matey so I'll let you know how that works out![]()
How come ?
you dont need to move both pumps, you just need to change the piping so that the "out" from the res combo goes to the "in" of the 2nd pump
How come ?
Would that really make that much of a difference, tbh ive drained my loop and tried to sort things out that much, my rig has been down more than up, getting really boring now lol, if you know what I mean.
Other than that I do not know how I could change my loop so it improves flow ?
IF it is purely the restrictiveness of the rads then putting them in parallel should fix that, however I don't think that is the problem - the fact you are getting no benefit from running a 2nd pump means there is something directly related to how the pumps are connected up that is causing the problem
if you turn off one of the pumps, what is the reading then? does one of the pumps being off cause more of a drop than the other?
Rads - did you mean GTS?
The gtx's arent crossflow but looking at your pics i can only see one connection to the top rad
I would check the direction on the mobo block as the pics i can find seem to show the top connector as the out but your pics / loop order desc show you using the top connector as in
What is the actual reading with one pump running? With both pumps connected but only one running it should only be marginally less than the 130odd you were getting with one pump
I've heard that the Nemesis are very restrictive rads, and the fact that you have that much component makes me think that you might be pushing the limit of D5 pumps?
I would suggest getting more powerful pumps or removing components instead of changing the loop order as your reading seems normal (70lph for 1 and 140lph for 2)
2x D5's is plenty and even so you still should be fine with 1x D5.. the most Laing D5(swiftech, EK etc) all have a pump rate of up to 1500 L/h.
i am only getting 151-lph. before adding the new pump into the loop i was getting 137-lph.
The radiators take nearly 1psi of pumping pressure each.
That's much higher then the 0.15-0.25psi other radiators of the same size from other brands cause.
HWLabs radiators are brutal for flow rate and 2 of them in the same loop can consume nearly 50% of a loops pumping power.
I think its the stupid cross chiller, I think I am going to redo my loop, and I have them stupid bubbles back in my cpu block. ahhhhr grrrrr. its not as if I did not bleed it I spent a whole 2 nights doing it, hours and hours.
