I find that banana flavours tend be more like the foam banana sweets than an actual banana, if that's makes sense?![]()
hahaha i should have prob added that it's more human error of spilling and making a mess not the cats actually opening the bottles to get their fix!
Yeah its too fake for me but it seems everyone thinks bananas taste like foam sweets![]()
Just used refilled my kayfun after 1 hr of using it with a new coil, and already with this 28g kanthal, just got a huge dry hit as if there was no liquid in it at all, not sure if its the way im filling it or something or what, last week like I say I did 5 days on a 30g kanthal coil and it was fine, 28g its not working for me, first half hour Is good after that meh, don't know whats happening to it.
And this coil I used half the amount of cotton I usually use, literally there the bare minimum amount or else it will just be a coil wire and no whick lol.
No idea whats going on with this 28g any ideas?
Sounds interesting but seems like a lot of messing about I mean I was annoyed at filling up my mini pro tank 2 every 20 mins of vaping and now on my kayfun im filling up every hour lol still a lot of messing about. Tho saying that two days in a row now iv built a duff coil, last one lasted a week but past two meh mustn't of been concentrating lol
The Plume Veil is a superb atomizer, I used one as my go to device for months on an IPV2.
Its been modded for more airflow too.If only I could get that Green tank and chimney seeing as I already have a black Kayfun.
Nah it's dead easy. You just bring a squeezy bottle of juice with you and when you need to top up you just yank the drip tip off and squirt a bit in. I regularly do it when I'm driving at a traffic light (or a straight road but that's not recommended). Give it a go, worth a punt.
Et voila
I have one myself along with a bag full of other colours actually. I've never used it as I got the glass tanks and if you want it, just let me know. No charge
Can't help with the chimney though.
Sellafieldwhat's powering your kayfun?
Ya know what I might get one to give it a go, any recommendations on a good cheap dripper? Around 20 - 25 quid budget?![]()
No probs Chris.
IceShock, what's powering your kayfun?
Used all of these
http://greyhaze.co.uk/collections/rda/products/doge-rda
http://greyhaze.co.uk/collections/rda/products/little-boy-rda
http://greyhaze.co.uk/collections/rda/products/mephisto-rda
Might be cheaper else where, this is just my local shop. all easy to build with cracking airflow for the price really cant go wrong![]()
 I never win anything!!!Nice! all three look good, which would you advise? also are they single coil or dual etc, like well the kayfun 3.1 has two screws to attach the coil to, though im guessing some people make two coils to attach to it, but iv also seen some drippers and stuff with 4 screws etc, id like to start on a single coil first
but I notice drippers have three screws? two positive one negative or something for dual coiling?
 However if you want to do single coil I am 90% sure you can on any of them with no problemsDidn't you get any spares with it?
My first one was the mephisto I had never rebuilt anything before, its surprisingly easy to do a simple dual coil build, if you can do single coil you can do dual coilHowever if you want to do single coil I am 90% sure you can on any of them with no problems
out of the 3 I would just pick which ever one you like the look of better, all easy to build on! takes me 5-10 minutes to strip clean re-coil and recotton and I've only been using re-buildable for around 2-3 months
 though iv vaped for 15 months now so I aint going to start smoking again because I couldn't be bothered to make two coils I guess haha
