Only £19.99 inc VAT - OcUK DOES NOT RECOMMEND THIS UNIT!!
ORDER NOW - DO NOT BUY THIS IT IS JUNK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I just lol'd at this
Is corsair AX760 any good power supply?
Been after the 750W EVGA G2 or the Superflower 750W for ages to come on offer with stock but never had any luck, as soon as the offer finishes 10+ stock shows.
[*]Coilwhine is not a fault,
See if I can put some on weekly offer for you.
With your superflower psu's do we have to pay to send it back to you after 1-2 years ?
The older none digital models are Seasonic and pretty damn good, better than the newer digital ones for sure.
That would be awesome! I just seem to miss the boat on them as I guess they are a very quick seller when under offer!
The way to tell is a corsair psu was the old seasonic made units the part code on the box is cmpsu-ax750uk if it is the new part code format cp-9020000-gb then they are made by their newer oem partner (mostly cwt)
What is the make of evga g1 650w? I believe it is not superflower, they only make it from G2 no?
yeah my mistake, G2 are Superflower, no idea who the G1 is.
