- 27 Dec 2005
- Bristol
No, unfortunately not, I was enjoying it from the basin with a few bevvies and friends instead
.No, unfortunately not, I was enjoying it from the basin with a few bevvies and friends instead.
Russ did you not fly and film for the Clifton Suspension Bridge?
Right the Hobbyking order arrived!!!
However a couple of initial things I can't seem to work out.
NTM motors - why the long shaft that points down the way - what the difference between long/short shafts??
On all the videos/pictures etc - the motor seems to mount like this (nice neat wiring that you can fed down through the arm etc to the ESC underneath.
However - the only way the screw holes line up is like this with the wiring going off to the side which looks awful and harder to get underneath.
Am I missing something? It only will mount one way with wiring off to the side.
Lipo Voltage Checker @ £1.92 at HobbyKing. Downside is it might take a week or 2 for delivery.
If you keep the page open for a minute or 2 you might get it cheaper.
As for the screws, there should be at least 2 that line up?
Got myself the syma x4 yesterday but need more juice for it. Read the 300mah batteries fit buy unsure where to get them from? Is there any way to charge a few at a time?
Would love to know more about this as well, im guessing the oem battery takes an hour or so to charge for only 5 mins flying time?
Just seen some of the aerial footage from the display and it's not amazing![]()
Yeah seems to take about 45mins for about 5 minutes flight time
You can charge multiple batteries at once with a proper charger and a parallel charge cable. Not familiar with Syma stuff, Banggood probably have something.
