** TWO INCREDIBLE PRE-ORDER DEALS FOR CHRISTMAS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got a couple of incredible deals for you and the AMD card comes with AMD Gold award and Civilization game code. :)
MSI Radeon R9 290X Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1030MHz
- Memory Speed: 5000Mhz (Samsung IC)
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
Was [£299.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Samsung S34E790C 34" WideScreen Super-Wide Curved LED Monitor @ £799.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
VA’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved VA provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 100% colourspace and VA’s accurate colour expression.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: VA
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 100%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 3000:1
- Response Time: 4ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 16.7M (8-Bit)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3000R
- Connectivity: 2x HDMI 1.4 (50Hz), 1x DisplayPort 1.2 (60Hz)
- USB 3.0 Hub: Yes x4 (1up 4down)
- Speakers: 2x 7W
- Tilt: -5 / +20
- VESA: 100x100
- Warranty: 2yr
Was [£989.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Both products and deals are exclusive to OcUK and are only whilst they remain on pre-order status, stock is due on both items mid-end next week. A cracking Christmas deal!! :)
God damn you Gibbo!
Ordered one of the Lightnings, can't say no at that price.
When you get it, fancy posting a review and please focus on the overclocking as these are LE edition with reduced 1030MHz core, so be interested to see how they clock.
The last time MSI did an LE of a Lightning with lower core clock they were actually clocking better than the full blown edition, so be good to hear your findings. :)
Will do. :)
hmmm co operation free card for matt me thinks :p. matt does review gets free card :D
also you had lightenings anyway matt.
The thing is by now these companies now how to tweak the components they use to get the best out of these cards and being a Lightning edition even if it is a LE variant I'm sure these will clock very well.
A very nice card at a fantastic pre order price, if your in the market for a new card and don't mind waiting a while then my advice would be to snap one up.:)
Good stuff.
Might order a couple to warm up my room and have a tinker.
Best 290X on the market, the only card which rivals the Lightning is the Vapor-X and you could argue the PCS+ is a good card, but at this price this card is hands down winner!
Bear in mind, this is a spot buy, MSI just sold me their inventory to get clear, we've pre-sold 20 already so we might be taking them off-sale soon as we only got 164pc coming in.
