I don't think so, my draytek will update boot loader when they was decided to change it via normal firmware update ... asos looks clearly they have update it & the other units should been affected and the same should valid for drivers ... if the boot loader does not change with asus here you go why some other units may have issues & other may not
EDIT
Unless Asus has not decide to update it yet for all units
cur ds_tone_estimate_new_flag on
cur ds_tone_estimate_min_snr_by_power = 3.0 dB
cur ds_tone_estimate_adsl_trend_ratio = 1. 0
cur ds_tone_estimate_echo_thres = -118 dB
near-end path0 fec: 86(461275888)
near-end path0 crc: 10(3489)
near-end fec sec: 7(212784)
near-end err sec: 7(1080)
near-end ses sec: 0(57)
near-end los sec: 0(0)
near-end ua sec: 0(218)
far-end path0 fec: 0(360573)
far-end path0 crc: 0(1742)
far-end fec sec: 0(6786)
far-end err sec: 0(1362)
far-end ses sec: 0(0)
far-end los sec: 0(535)
far-end ua sec: 0(23552)
outDiscards=15
inDiscards=5253
outBytes=1724305271
inBytes=1641686263
outPkts=34673133
inPkts=39227199
fwVer= FwVer:5.5.1.126_B_A60901 HwVer:T14.F7_0.1
lineState=up
Opmode=ITU G.993.2(VDSL2)
SNRMarginDown=8.9 dB
AttenDown=10.4 dB
SNRMarginUp=12.4 dB
AttenUp=0.1 dB
DataRateDown=74689 kbps
DataRateUp=20000 kbps
WanListMode=1
FECDown=86
FECUp=0
CRCDown=10
CRCUp=0
HECDown=0
HECUp=0
ADSLUpTime=16 min, 23 secs
ADSLActiveTime=0 min, 19 secs
PowerDown=12.8 dbm
PowerUp=6.4 dbm
AttainUp=29061
AttainDown=88624
ShowtimeStart=19
TotalStart=158
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=1
AdslStandard=VDSL2
AdslType=ANNEX_B
mtenStandard=G.dmt.bisplus
I have just got one of these for testing from Asus what with all the issues with it. I installed it last night and have had a pretty consistent connection since then on Plusnet fibre. Does it take a while for it to start having disconnects. Although it does look like I have had 4 disconnects this morning. only for a few seconds and then it finds the connection again. I will keep checking on the connections throughout the day. The firmware has been uploaded as well to the latest full version. _2155. I am not sure if there is a higher Beta version out there but I will be working with Asus like the rest of you to get the issues fixed.
it does look like I have had 4 disconnects this morning. only for a few seconds and then it finds the connection again. .
near-end path0 fec: 33812(461280290)
near-end path0 crc: 5839(3825)
near-end fec sec: 218(212932)
near-end err sec: 217(1227)
near-end ses sec: 59(116)
far-end path0 fec: 29(360602)
far-end path0 crc: 3(1745)
far-end fec sec: 6(6792)
far-end err sec: 3(1365)
outDiscards=15
inDiscards=5584
outBytes=2162650419
inBytes=2509581985
outPkts=35652634
inPkts=40365350
lineState=up
AttenDown=10.4 dB
SNRMarginUp=12.2 dB
AttenUp=0.1 dB
WanListMode=1
FECDown=33812
FECUp=29
CRCDown=5839
CRCUp=3
HECDown=0
HECUp=0
ADSLUpTime= 2:44, 23 secs
PowerDown=12.8 dbm
PowerUp=6.4 dbm
AttainUp=28743
AttainDown=88948
ShowtimeStart=19
TotalStart=158
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=1
AdslStandard=VDSL2
AdslType=ANNEX_B
Yes I have had a few more disconnects since I looked this morning. I had sent the details to asus and got a quick response on some setting to change. I have made those now and will see how long that lasts. I will run a speedtest when I get home as I dont like doing it via VPN. I will then compare that to ones I have saved with the OR modem and a TP-Link router.
Yes the rest of the settings are really good. will see how many more disconnects I get.
.What's confusing me is how mine can be online with Fastpath for over 10 days, interupted only by me, and have 480709876 FEC's but no disconnects...
After a few changes to the settings mine does seem a little more stable now. I have been using VPN all day and not been knocked off once by it. Only when I rebooted the router was there a drop. I will be checking speed checks later on.
