- 19 Feb 2007
- Northampton
I ended up just buying a tube of IC-D, Haven't put it on my GPU yet but CPU is running nicely
Good man as I have the same cardgood to know as the standard paste they put in it is quite worrying, as you will soon find out.
PM trust me your addy and ill get some sent out.
regards
frosty
still awaiting more to arrive from hq fella
It's most likley that you would have seen a similar drop from a good paste such as Gelid Extreme or MX-4. All this praise of IC-D is pointless without comparisons to other tim's. In my pc it made no difference on the gpu and less than 1 degree on the cpu.
.Note: Comparisons are an average of results on each test platform and reflect that as higher thermal densities (area/watts) increase thermal performance differences increases between compounds. High thermal densities pose a unique challenge for thermal pastes because there is a large amount of heat passing through a restricted area. This challenge, however, is where IC Diamond shines in its ability to dissipate heat even under such intense and extraordinary conditions. The dismissive claim that "all thermal compounds perform about the same". Not true. A high performance racing car might idle as well as a CPU. but the true test is to take that car on the road and see how it handles under stress at high speeds.
This is demonstrated by comparing notebook and desktop CPU tests, notebooks while having perhaps a CPU that runs @ 35 W vs. a desktop @ 95W will run much hotter with a 2X delta increase in compound performance due to the increased thermal density @ one third to one half the power of a desktop CPU
Results
Results show that careful attention to contact and pressure can yield significant benefits and that performance requires having both good contact and good pressure.
The total span of temperatures in the sample group ranged from -5ºC to +3.9ºC, a non trivial 9ºC spread due to either contact or pressure.
I had some ICD in the draw for around a year. When I got a new cpu I got it out to put some on and it's rock hard. Is this normal? No other paste I've used has ever done that in a sealed tube.
Surely the overriding factor here is the removal of poorly applied stock TIM?
I bet if you used the same stuff but cleaned the die and applied it properly there'd be next to nothing in it.
I have some IC-D coming in the post, I also have some TIM that is supplied with my yet-to-fit CPU cooler, I think I'll do a little test.
