That all looks sensible. The one thing I would say is that the Comp Pro is carbon so the frame won't rust, but it could be carrying unseen damage if it's been crashed. Short of getting the frame x-rayed you'll just have to give it a good look over and then you're going on trust, really.
Thanks,
It's listed as a Comp Pro but specifies an aluminum frame with carbon forks. So I think it's just the Boardman Comp and is priced accordingly.
Will stick a snap up tonight if it all goes to plan
