Hi Mate
I do, runs sweet, no complaints
Nice, do you know if its the Pi that does the video decoding or if its the source? My content all sits on a NAS.
Cheers!
Hi Mate
I use a Pi on my kitchen TV, running OpenElec.
The menu's are slower than using on a PC, but it's not a dreadful experience. All videos play fantastically on it, no complaints in that department.
My Pi does the decoding.
Personally, I wish it was a bit faster in the menus.
If I was adding another, I think I'd seriously consider one of these..
http://www.solid-run.com/
Either or Cubox or a Hummingboard.
Not cheap? Look great though
, should be out any day now..I think £75 + shipping is pretty reasonable. Especially as I would probably still get £50odd for mine. It would be a cheap change over.
Fair point..
It's got more features, better performance and is considerably smaller than my current HTPC.
The only thing mine has an advantage of is a full blown SSD in it with 128gb of storage. Otherwise it trumps it in every way.
Gotta be done I think!![]()
You have an SSD in yours![]()
MELE F10 3 in 1 Fly/Air Mouse+Wireless Keyboard+Remote Control
What are you guys using as remotes for the XBMC units? I use my iPad but it's clunky to say the least, the forest has some nice remotes but just looking for cheap and effective unit as it's not used a great deal
Thanks
At least you lot have your systems running I can't even get mine to run without freezing.
