- 8 Oct 2009
What's that Skyfall? Yes a bulb but what sort![]()
It's a LIFX smart bulb... Kind of want one for my cinema room, but I think it's a bit expensive for a bulb (and I only need one!)
Just got stung £195 for GHD straighteners and hair dryer.
If anyone needs a 10% discount code I have one available. Given after the purchase, very nice of them......
Not for both surely?Did you not see a thread made last week where you can get them for under £100?!
Been an expensive month.
New bed frame and blinds.
Do you have to raise and lower each blind individually?
As soon as you mention 'bay' windows anywhere the price increases exponentially for what is effectively the same product.
I've got bay windows in the sitting room and master bedroom, and at the moment it's a thin plastic curtain rail screwed to the ceiling which makes it nearly impossible to pull the curtains at all, let alone in under 10 minutes. I considered blinds, but what were you quoted for curtains?
I got it for £50 and have seen some going for £40 so not as bad.Lifx bulb. Pretty awesome stuff but £80 for a single bulb is waaayyy to expensive.What's that Skyfall? Yes a bulb but what sort![]()
I wanted a dimmable bulb and also wanted to try a sunrise alarm, those alarms are around £50 anyway so I figured it wasn't that bad of a deal.At that price... I would expect the lighting to follow me around the house automatically if I had my phone on me, at least![]()
I didn't see that, but then again I joked about buying some cheap knock-off ones a few days ago, the look I got would cut you.
Apparently the rose gold limited edition set are farrrrrrrr better at doing...whatever they do.
I miss that mouseWhat keyboard is that you have?
New toy for work, thankfully the software is nice to use and a lot better than the ancient POS I've had to use up until now.
