Any XB1 people online want to run the weeklies?
yeah 2 secs coming on now
Void burn, always a tough call for nightfalls. Do I go Voidwalker for extra damage or Sunslinger for the extra protection on nightfall.
Definately going to run Preadyths Revenge, usually use corrective measure but might give truth a go this time.
That's why i said with a few exceptions. Obviously there'll be some bad and some good of each type so you'll have to actually sit and look at which would be better for your playstyle.
I've got the calling that has identical stats/slightly higher impact (with armour piercing and third eye) and it hits for 15% more damage on every hit. Yeah i have to pull the trigger, but if it hits better than the VoC then i don't care. The saterienne rapier from the crucible quartermaster is also MILES ahead of the VoC as it has the firefly perk, same as the fatebringer. Obviously i'm not saying every 331 is better, that would be moronic. But if you look around there are better 331 weapons for most types, so if there's a decent, easily obtainable replacement, then you'd be stupid to stick with the lower damage weapon.
The only time the VoC will still be applicable is upon taking out loads of solar shield enemies or for a solar burn weekly event. Outside of that, it just isn't the king anymore.
How can i get a decent AR? I can't do raids because I can't mic.
I've got that Payback SOS thing. It is dreadful.
I've got it maxxed at 331 and it's my main primaryI like high recoil ARs, makes the game more fun for me.
I'm also disappointed by just how rubbish the atheons epilogue is. Seems every time a void burn comes round it seems a hell of a lot worse than it did the previous time i played with it.
Wait till we get CE raid primaries... if it's any good that is.
played for ages grinding the blades of crota on earth and then over the last weekend grinding that silly map to get the Husk of the Pit gun. Guess wot - two days later it drops again whilst killing blades on earth - pffffft.
Do we get anything for dismantling it?
