- 20 Dec 2014
Has anyone managed to install android on these tablets?
Ah okay, that's perfect then. I'll probably never have a USB device attached but being able to use my portable battery charger is imperative for trips.
So has anyone tried to read a PDF/ebook on one of these? I was disappointed with the iPad Mini 1's screen, and Linx 8" only has a few more PPI that that.
Has anyone managed to get Windows 10 Technical Preview fully working on the linx 10. I can get it to install and make the touch screen work correctly, but I can't get the wireless to work. The driver installation won't install and I can't cancel it. And if I force it to shutdown to get out of the installer it totally breaks the Windows installation.
I have plugged my Linx 10 in to a USB charger and it did nothing at all.
I had found new Realtek RTL8723BS Wifi/BT driver last month and installed over default old driver Linx supplied, worked great so you could try it see if you can get new driver install on Windows 10 without issue.
http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=CFMTN
I managed to get the wireless working using the driver from the chinese PIPO W1 Tablet from here https://social.technet.microsoft.co...g-on-pipo-w1-tablet?forum=WinPreview2014Setup
Oh brilliant find.That driver is newer version 3007.5.0815.2014, downloaded it on Linx 10 and installed it, worked great. Glad the new driver is compatible with Windows 10.
You might find up to date drivers for the 'Schenker Element Tablet' also work. You need to google it to find the website as they sell other things.
Thinking of maybe treating myself to one of these, i was a little put off by the screen resolution as i was looking for something that has 1920x1080 but the reviews seem to be pretty dam good for these. I have an ipad mini but i wont lie i have always preferred windows over anything else and with this being a full windows 8 install as well its a no brainer surely? Thinking of the 10" version
Are these good for picking up and just browsing the web etc? Wasnt sure how easy it would be to do quick simple tasks like this on a windows platform especially on a tablet
