Thanks very much for that mate, just need to decide weather to take the plunge and pick one of these up! Seem to be around the £160 mark at the mo. I had looked at smaller models but thought the extra ram in the 10" would keep things running a little smoother
If it's just the ram you're worried about then I wouldn't be put off by the 1gb of ram in the smaller models, even with a fair bit of multi-tasking the linx 8 seems to cope well with lots of windows 8 apps running. Windows seems to put them into a suspended state when they're in the background and task manager reports that they use basically no ram. Also I play hearthstone frequently on mine, a game which has a minimum ram requirement of 2gb, and it runs absolutely flawlessly.
Clearly if you're planning on doing heavy multi-tasking using conventional .exe programs then this will probably pose more of an issue. Still, I've had dropbox, steam and firefox running at the same time with no problems.
