Fitted some xenons to the E46. Won't put pictures up as they've been modified slightly and I fear the backlash from Fox
Also ordered some MTEC hybrid wiper blades, they look similar to OEM so should look reasonably good on the car - and hopefully perform well on the car too.
I don't rate the MTEC hybrid ones at all really, the driver side doesn't make fulll contact in the middle mid wipe leaving a wet patch on the downstroke. I've gone back to Alca blades for the E46, just such a better blade in both design and wipe quality across the entire blade.
Also, questionable mods on the E46? You sicken me!
As Shaun says, wheel woolies are amazing. If your wheels are anything like mine to get between the spokes properly clean you'll need to wrap a microfibre around the handle of the smallest brush, but the rest of the woolies make short work of the rest of the wheel.
Cool cool, I look forward to the elbow grease to come
