Just curious as to what difference the CSL ECU makes?
For quite a bit.
My car is early 2002 so it has the earlier MSS54 ECU, 2003ish cars at somepoint got the faster and larger memory MSS54HP ECU.
Then on the CSL version it has far more aggressive mapping, so on the regular M3 map, if ignition target cannot be hit it will retard timing by a whopping -2.0, whereas in the CSL it will hold ignition and only reduce if absolute necessary and then it will reduce by the amount it needs to reduce by and not just a number picked out the air.
The CSL map is also much better than the regular M3 map, come on how do you think they managed to take claimed PS from 343PS to 360PS, a lot of it was in the mapping as the only actual hardware changed were CSL air box, CSL cam (hardly any different though) and that is it. The exhaust is identical flow wise, all they changed on the CSL exhaust was the materials to make it lighter but flow characteristics are the same.
The CSL also used a map sensor and IAT sensor again to allow it to be more aggressive, faster reacting and giving better drivability, these are parts I shall be adding in when I do this conversion. In short I will have ultimate drivability, maybe upto 20BHP increase in lower areas of the rev range because no offence to the great remapping companies out there but BMW did a better job, top end I will probably gain nothing compared to my current Evolve map, maybe a bit less.
Once I am all up and running the car will go to Evolve for them to dyno as is, to compare the result from how it ran with their map and then they shall map the car to the standard M3 cams to see if they can improve it at all, then at a later date I shall add schrick 280/272 cams with map to match which should net a real 380-390BHP from the car.
But the CSL ECU I want really for drivability, the CSL's were a much better drive, it is hard to explain but in order of drivability:
1. Real CSL Map with CSL setup - AMAZING!
2. Stock M3 - Pretty epic!
3. CSL air box with Alpha-N map - Damn good, but the above two have better drivability.
Some people might say I am crazy as what I am doing (ECU Swap) will probably yield no more ponies to brag about in the pub but having better drivability such as smoother power delivery, quicker throttle response, absolute no hesitations anywhere no matter how much you floor it from low rpm's and gaining torque/power across the rev range is better than peak gains. Plus having an ECU that runs your engine essentially in realtime and is not being conservative because it is to slow to keep up, the benefits are great. Plus this kind of modification really adds value too.
