That is a good 980 you have got there
Very impressive.![]()
.I feel i could get a bit more out of it too if i wasn't having a few issues elsewhere.
I noticed that pressing F12 when using Mantle now gives screenshots for this in stream.![]()
Now only if we could record Mantle gameplay properly![]()
If you're not getting on with Raptr, you can use Mirillis Action or any other desktop recorder to record Mantle footage. Crossfire works in borderless/Window mode in Mantle. (but it does come with a performance hit)
You can with Raptr![]()
Here
Raptr - Mantle - Thief - AMD TrueAudio - 60fps:
anyway that's a very nice score Matt, your min and max are also consistently higher then mine from my testing.
Thought i posted here last week?anyway that's a very nice score Matt, your min and max are also consistently higher then mine from my testing.
I'm going to allow myself a few Heineken in an hour or so and try get back top spot. Wish me luck![]()
Cheers pal, gotta keep you on your toes.![]()
