- 20 Apr 2004
- Rugby
So then *rolls up sleeves*
Possibility here of 5120x2880 @ 144hz with G-Sync and a proper 10bit IPS panel? Not bad but i can nitpick a fault as amazing as that setup sounds.
:s
4k @120mhz is not going to happen until we see DP1.3 in products (there's support for dual 4k@60mhz in the 1.3 spec) as V1.2 simply dos'nt have the bandwith.
144mhz will probably need a new display port version after that. Anyway you need a small render farm to game at that resolution a speed. Unless all you play is CS:S or Quake 3
you stick with tn then but i know what i would do
