Yeah, as of tonight I will probably go back to connection settings specified by DLM at the moment - until the rollout is effective on my line (assuming G.INP will be enabled all of the time rather than when DLM sees fit - it would seem stupid if it's not enabled in the background all of the time).
Not sure who your ISP is, if it is BT the DLM system checks things daily, does not necessarily do anything though. If the Asus has a LOG or similar function and you go through that you will soon see as and when your ISPs DLM system snoops on you. BT and i think Plusnet use TR069. If the asus LOG has filter options to view things such as DHCP TR069 etc select TR069 and you will spot a pattern.
I have good news
Apart the DSL part ... about end of March will be added ADAPTED QoS which has already the RT-AC87U / RT-AC68U
http://nw-dlcdnet.asus.com/AdaptiveQoS_Bandwidth_Monitor.asp
http://nw-dlcdnet.asus.com/QoS_EZQoS.asp
A nice little bonus
If it is anything to go by the BT Wholesale test has my d/load at 31.9Mbps, my upload at 8.69Mbps and ping at 19.63ms.
Do a stat dump and it will be 100% clear if you are interleaved Not sure of the command for Telnet of this device to show INP and Delay figures though. (Babis and Ixel probably know)
However If that is a 40/10Mb service its only going to be light interleaving, at most. Id guess 8ms and possibly INP 01. Certainly be shocked if worse than that.
