It's all about upper and lower limits and lies Iceshock.
All devices that are regulated are restricted. Some devices cannot go bellow a set voltage 3.2v-3.7v. A more expensive mod might have a lower limit of 1v. This is done in hardware.
All regulated devices have an upper limit this can vary wildly. 4.5v, 8v, 12v ect This is done on the DC boost circuit.
In both cases devices often lie. Not in a malicious way (unless it's a cloupor). But because the software and the hardware can have an overhang.
My device is an E-Holly 35W. It will go from 7W-35W and it will fire at 0.5 to 3 ohms. The E-holly can not set a voltage under 3.2v. And it can not set a voltage over 8v. On screen however this device appears to be able to fire below 3.2v because the screen and the wattage can move under that 3.2V limit.
This means my screen lies to me. If I put a 0.5 ohm coil on it then the lowest wattage I can pump out is about 20W's. Even if the device tells me it's 7W at 1.9v I know that the device will always be pushing 3.2v. So I can turn the wattage from 7W-20W and the vape is always going to be the same. The device will regulate between 20 and 35W like normal.
Upper limits are similar. If the device can only give 8v as a total output then regardless of what the screen says in advance of that it's a lie. So a 3 ohm coil on my device at 8v is 20W's. So at 3 ohms my device is only 7-20W's.
This calculator is a godsend as it will do the work for you if your in any doubts.
http://www.rapidtables.com/calc/electric/watt-volt-amp-calculator.htm
The VAMO v6 is a 3-20W device. And the voltage limits are 3.0v - 6.0v.
The ohm range is 0.8 - 5 ohms.
So the 0.8ohm range is 11w - 20w
The 1.5ohm range is 6w - 20w
The 3 ohm range is 3w - 12w
The 5 ohm range is 3w - 7w
All the time the voltage is the limiting factor up to the point where the device hits it's wattage limit. So for the V6 1.5 ohms gives you the full range of wattage and the voltage sweet spot.
Ice shock, sigelei 100w.
http://www.ukecigstore.com/sigelei-100w-box-mod.html
