@melmac:
Trademark:
It doesn't matter which one you think might potentially gain more. That's not how TRADEMARK royalties work. If there is some other kind of agreement, that's their business. But it's outside the trademark royalty issue.
And for the record, I did consider it (the part about who benefits more), but like I already stated, I just disagree with it. You do understand you are disagreeing with my opinion, just the same?
"Adaptive Sync -compatible" or "variable refresh rate compatible":
... Are you arguing with me on a technicality, or something? Fine, they'll say it "supports"/"uses" (or whatever word you want to put in there) Adaptive Sync / variable refresh rate. Either way, the point was that they can still flaunt the Adaptive Sync / variable refresh rate, no matter whether they even mention Freesync or not. Or are you suggesting they wouldn't want to mention them at all?
Product/service/etc:
It would also seem I would have to explain the wider concept of a product, as well. Which I'm not going to. In short, when you're talking about a product, it seems you're talking more about a physical object. I'm talking about a product in the marketing sense, from a company's perspective. That includes not only physical objects, but pretty much anything you can put a price on. Anything you can collect money from, is essentially a product for the company holding the rights to it.
R&D:
I wasn't kidding when I said I won't go further into that. If it is indeed that AMD's R&D for Freesync was 0€, then yes, you are correct, they have nothing to recoup. I strongly disagree with that assessment, though.
Pricing:
Like I said, "on how much they could and could not get away with". If you want a term for it, then "consumer/market psychology/behaviour". Freesync has created hype around itself, which AMD can take advantage of.
Links:
?? As I recall, those links were to prove that Freesync=/=Adaptive Sync. Which they actually did prove. Although they weren't needed, because I just confused your replies as if you were suggesting they would be the same thing.
And I don't remember finding anything that would actually DENY the monitor component. But because there's no mention of it, either, I took your word for it, instead. Even if there WERE a physical component in the monitor, those articles would probably still hold true. So at the moment, I'm actually just trusting your word on that (combined with the logicality of there being no mention of it).
But I agree with Marine-RX179, this is going too off-topic, so let's try to wrap this up. In essence, we are disagreeing on so many fronts, so I don't think it's worthwhile to continue, when we have so radically different views. So I'd suggest we'll just agree to disagree.
