- 7 Aug 2004
Christ how does this happen? It's obviously all about who you know not what you know, no greater evidence of this!
Ammonia leak caused crew to evacuate to Russian section, but now confirmed it was a false alarm:
https://uk.news.yahoo.com/toxic-leak-international-space-station-russia-121805828.html#nUcCi68
Many scientists assumed it had been destroyed in a high-velocity impact.
The new pictures, acquired by Nasa's Mars Reconnaissance Orbiter, give the lie to that notion, and hint at what really happened to the European mission.
Beagle's design incorporated a series of deployable "petals", on which were mounted its solar panels.
From the images, it seems that this system did not unfurl fully.
"Without full deployment, there is no way we could have communicated with it as the radio frequency antenna was under the solar panels," explained Prof Mark Sims, Beagle's mission manager from Leicester University.
"The failure cause is pure speculation, but it could have been, and probably was, down to sheer back luck - a heavy bounce perhaps distorting the structure as clearances on solar panel deployment weren't big; or a punctured and slowly leaking airbag not separating sufficiently from the lander, causing a hang-up in deployment," he told BBC News.
A set of three observations with the orbiter's High Resolution Imaging Science Experiment (HiRISE) camera shows Beagle 2 partially deployed on the surface of the planet, ending the mystery of what happened to the mission more than a decade ago. They show that the lander survived its Dec. 25, 2003, touchdown enough to at least partially deploy its solar arrays.
wheres the dramatic video you promised us in the thread title?
EDIT: thanks for the update/edit
i dont watch adverts though so il take your word for it being dramatic n stuff![]()
. Didn't even realise there were adverts in the first video until you said and I quickly turned off AdBlock.
but to claim it was lost due to luck is a bit of a stretch
