***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Vapemail!!
Pwoarh jesus Christ, this belts some vapour out! I definitely need to cut the nicotine out now, at 6mg this thing give me such a throat and lung hit im coughing a few mins later still lol. You know how I was always saying I liked a cool vape, well petey I copied your build as much as I could and the warm vapour is nice!
Kayfun V4 is going back in its box though, damn thing doesn't work, iv done every coil design thinkable, all amounts of cotton from hardly any to stuffing it with it and it just dry hits all the time, cant be bothered with kayfuns any more.
I give it a soak over night to remove all the machine oil, which worked it doesn't have a foul taste now when it works, but I cant get it to work consistently, Besides I don't need it anyway, got the dripper for home, and protank for out and about.
Im impressed how good the sigeli is, how powerful it is!
Also, impressed with these efest batteries, iv been chain vaping for about 45 mins, they've gone down 2% @ 40w!
Also impressed with 24g kanthal... 28g and 30g look like little whimps compaired to this beasty stuff!
The Vamo is a great mod, but stuff like the Sigelei is just in another galaxy in terms of performance!
What charger are you using for the Efests?
No idea what it is, heres a picture:
Got it with erm, think it came with my vamo actually. and iv got a spare one exactly the same as one came with my super-duper green lazer pointer that iv got, that's the same size as my vamo actually :p
would you not recommend this charger? if not, what would be better.
Cheers
Cheers
That looks like a generic Chinese charger, if it is a good charger or not I honestly don't know.
I would recommend a Nitecore charger, I have the i2 version (2 bay) and it is excellent. Very inexpensive and it is "intelligent" which means it automatically detects the battery chemistry and uses the best charging profile for that battery type. It is also optimized to charge IMR batteries like your new Efests.
The one you have may be fine, I personally think it is worth investing in a nice charger to extend the life of your batts and for a bit if added safety. :)
Nice one dude :) (Iceshock)
Slinxy, what don't you like about the screen?
It's a personal thing, I just don't like the boxed layout out of it. When compared to other screen layouts it just looks ugly. If I could get one with a different layout like the DNA or the SX screen layout, I would buy one in a heartbeat.
Fair enough.
Personally, I'm happy as long as it displays what I need to know in a simple enough manner.
Status
